How do I take off the IMRC of the IM?
not necessary. i was toying around just the other day and had to install my new engine wiring harness and all i did was took out the 10mm bolt holding the cable in, then undid the cable and the IM comes off without needing to move the IMRC. it sits on the rear valve cover
There is small, eraser-shaped piece of metal at the end of the cable that slides out of the butterfly acutator so you can disconnect. It's just like the throttle and cruise control cables on the throttle butterfly.
, easiest way
Got it thanks, I just had to pull a bit harder. i didn't know if I was goign to break it or bend the piece it was attached to but it seems all is well. Now I am at work and have to wait till tomorrow morning to work on it.
, once lined up properly it should have slid out no issues
EricL
Jul 25, 2002 02:12 AM
EricL
2G CL Frequently Asked Questions
Jul 24, 2002 03:51 PM
