Hot Air
Old Apr 29, 2025 | 02:55 PM
Keithstoneice's Avatar
4th Gear
Hot Air
My car 2000 TL likes to start blowing hot air underneath the steering column after driving a while only thing that helps is turning on AC which I don't like using, any suggestions on what i should look for?
Old Apr 29, 2025 | 04:11 PM
The graphic below shows the ducting for your car.
Duct - 2000 Acura TL 4 Door TL KA 5AT
Old Apr 30, 2025 | 11:01 AM
jmk2003's Avatar
"blowing hot air underneath the steering column after driving a while"
do you have a hole in the firewall? there are several firewall penetrations for column, pedal rods, electrical
connectors....mess with anything in this area lately, or correct some other issue that may have brought this on? Does this hot air smell like _engine bay_?
I read your statement as 'after the car has been moving down the road, I begin to feel heat in the form of air from under the wheel, and that only turning on the a/c makes a difference'.
That said, if using the a/c clears up the problem, it might not be the ducting system, IMO, but I'm usually more wrong than right. :-)
Christina Obriant
4G TL Problems & Fixes
May 8, 2017 12:08 PM
hotwheljoe
Aug 20, 2007 11:04 AM
ChrisB88
Jan 23, 2007 05:31 PM
03Silver-S
Aug 15, 2006 02:35 PM
adonis_xu
May 6, 2006 10:17 AM
