Hope it's not bad tranny
Old Sep 28, 2018 | 02:27 PM
Darron Johnson's Avatar
6th Gear
My accelerator pedal is stiff and the car overrevvs and jerks aggressively and the check engine light is on and uses alot of fuel..I replaced map sensor (p0108 code) but it still having issues...plz help can't really afford another car right now 😭😭😭
Old Sep 28, 2018 | 02:29 PM
horseshoez's Avatar
Latent car nut
Have you checked the level of ATF in your transmission? When was the last time the transmission was serviced?
Old Sep 28, 2018 | 03:06 PM
6th Gear
I have no idea I bought the car used about a month and a half ago it's kinda my fault for not taking it to shop after the purchase I was in a bind and really needed transportation and the guy seemed like an honest dude....it's had 166k on her but I put about 1.5k or so on her since then...the tranny fluid level is correct by my knowledge
Old Sep 28, 2018 | 04:40 PM
read the code..It'll give you a start
Old Sep 28, 2018 | 08:44 PM
6th Gear
The code was p0108 which is map sensor voltage to high..I changed the sensor and it's still doing it
lokee99
Sep 18, 2006 04:00 PM
lokee99
Sep 15, 2006 03:41 PM
wside09
Jun 22, 2006 09:28 AM
ThoroDredCLS
2G CL Transmission Recall Q & A
Oct 18, 2002 02:08 AM
