High gas consumption
Is it me or just the way of the car. But my 03 TL type S seems to consume the hell out of gas like no tomorrow. There is no gas leaks or any mechanical problems of that nature. It feels like it only gets like 12 mpg. Now thats BULL S#!T
.Does anyone have the same problem and if so did you do anything to fix it? Any suggestions will help.
I haven't actually done the math. I'm probably exaggerating a little but i do know there is a significant difference in the fuel consumption then from when i first got the car.
winter fuel is a lot different then summer fuel man i run 330-350 km per tank a week!!! i got so pissed off, summer time i run 450-530 km its what they put in the gas in the winter to help the gas from freezing
Bonki' Ehrite!
.Does anyone have the same problem and if so did you do anything to fix it? Any suggestions will help.I've been thinking the same thing....I only use Chevron 93 octane, seafoam when necessary, and keep up with maintenance. Still though, my mileage as of late has been horrendous.
Until you calculate the mileage (driving as you typically do, where you typically do), it's just a guess-
Have you checked the usual things, such as tuneup (mentioned), tire pressure/condition, air filter, etc.?
buddy i got the same problem, ive changed my spark plugs to iridium NGK , changed my air filter ..... and my fuel consumption didint change .... now i switched to sunoco ultra 94.. lemme see how that comes along....
if things dont get better im gonna clean the EGR valve.... looks like im running out of options to increase fuel consumption my self
Bonki' Ehrite!
Well guys, I cleaned my EGR port, entire IM, TB, etc...Ran a bottle of fuel injector cleaner, lubed up the throttle cables, etc on Wednesday night. It took a few hours to get everything done, I don't know if we were just working slow because it was the first time, or we just were very attentive to all the details.
Anyways, I drove a bunch since then, and my mileage seemed to improve a lot....But, when I fill up next, I will keep you posted with my lileage.
i use mymilemarker.com to track my mileage...
usually about 15-18 if doing mostly stop and go
took it on the highway regularly for a week (~17 miles hwy and ~5 miles stop and go each way) and got about 28-29...but there was a brief period of extended WOT in there
joflewbyu2
Oct 8, 2015 11:16 AM
