hidextra kit owners
Old Mar 4, 2011 | 05:13 AM
yoon's Avatar
hidextra kit owners
for those of you with hidextra kits, how are you guys running the wire that connects to the bulb out of the headlight housing?
i just got my kit tonight, and the wire that plugs into the bulb is at a weird angle and is kinda bending while its locked into place. the only way i can see running it through is either through the bottom of the housing where the stock ballast is, or drill a hole in the back on the headlight cover...
any input is appreciated. thanks in advance
Old Mar 4, 2011 | 10:44 AM
01tl4tl's Avatar
are you doing the bulb and ballast kit? so the OE ballast will get removed
if you can use an existing path- do it
if not- thats why they make dremel tools
call them and ask for help--not the first TL to install their stuff
did it come with the adaptor wire- as seen in the threads on here
Old Mar 4, 2011 | 12:26 PM
yoon's Avatar
yea it comes with the adapter wire. funny thing is though, that even if i dremel through the cover, the way that the wire locks into place, its gonna get bent regardless. i guess im worried if thats gonna be a problem of any sort in the future..
oyayjoe
Jan 1, 2019 10:17 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
Zonian22
Nov 14, 2015 01:20 PM
oyayjoe
Sep 12, 2015 04:40 PM
nuldabz
Sep 3, 2015 05:49 PM
