hidextra kit owners
hidextra kit owners
for those of you with hidextra kits, how are you guys running the wire that connects to the bulb out of the headlight housing?
i just got my kit tonight, and the wire that plugs into the bulb is at a weird angle and is kinda bending while its locked into place. the only way i can see running it through is either through the bottom of the housing where the stock ballast is, or drill a hole in the back on the headlight cover...
any input is appreciated. thanks in advance
are you doing the bulb and ballast kit? so the OE ballast will get removed
if you can use an existing path- do it
if not- thats why they make dremel tools
call them and ask for help--not the first TL to install their stuff
did it come with the adaptor wire- as seen in the threads on here
yea it comes with the adapter wire. funny thing is though, that even if i dremel through the cover, the way that the wire locks into place, its gonna get bent regardless. i guess im worried if thats gonna be a problem of any sort in the future..
mrkingstonvi
02-22-2016 01:53 PM
Zonian22
11-14-2015 01:20 PM
oyayjoe
09-12-2015 04:40 PM
nuldabz
09-03-2015 05:49 PM
