HID problem..need answer please!!
Old Mar 13, 2013 | 01:41 PM
Bird2003TLS's Avatar
My 2003 TLS, when i turn on the head light, on the passenger side come on about 5-10 second then start blinking about 4-5 times and shut off. Anyone know what is wrong with it?, please let me know...thank you.
Old Mar 13, 2013 | 01:45 PM
closetprisoner's Avatar
2000 Acura TL
You need a new HID bulb..
Old Mar 13, 2013 | 04:33 PM
3.2TLc's Avatar
Yeah, the bulbs do wear out !
When you proceed to remove the old bulb, check the wiring connector to make sure that it was previously secure. Also inspect for any signs of moisture or corrosion, as either could cause problems.
Check the DIY sticky and other previously posted threads on the HID lamps for more info. The passenger side is relatively easy to access with a T-20 security. Use a latex glove if touching the glass part of the bulb. Take time to observe the bulb's retaining clip position, it can be tricky.
Old Mar 13, 2013 | 06:10 PM
victus1's Avatar
You're gonna need to replace both headlight bulbs. The old one will look dimmer and a different shade of color, usually pinkish.....plus the old one is due to die soon. It will look better if you match both bulbs now.
Old Mar 13, 2013 | 10:12 PM
thank you very much to you all...
Old Mar 13, 2013 | 11:18 PM
01tl4tl's Avatar
you will need a new ballast at some time if not already
if you have not staying on--flikking switch restores for a while
you need a new hid kit ,, replace the ancient waterlogged parts
www.hidextra.com has awesome deal 59$ for 2 new bulbs 2 ballast and power leads to bulbs
mention azine for 15% off
suggest 5000k bulbs for best to see with
Old Mar 23, 2013 | 02:07 AM
Shawn Savre's Avatar
5th Gear
I have an 02 TL that Im havin issues w/ the OEM HIDs and i like your idea, however i would like to kno wut bulbs i need to get to fit my car or does it matter? Please help!
Old Mar 23, 2013 | 02:58 AM
Naija'sTL's Avatar
You should be fine with D2R bulbs. They are the stock Lo-Beam bulbs for our cars.
Old Mar 23, 2013 | 11:31 AM
01tl4tl's Avatar
the TL uses a D2 bulb,,the last letter designates which base of the bulb
those are special HID bulbs that operate with a 20,000 volt system!
normal lights are 12 volts
ck website and call www.hidextra.com they will get the right parts in your hand
59 bucks for complete new system of ballast and bulbs
suggest 5000k color bulb and the normal 35watt ballast they sell
look for coupons or ask for the special acurazine pricing = save 5 bucks!
dont need the extra-extra small ballast or the optional wiring,,
we are simply replacing old parts of current hid system,
cut into the existing power wire and connect new wires to original = simple
for the effort to replace the bulbs.. only to have ballast be your other prob,,do it once and its good! remove nose of car to do
if you see moisture inside headliight lens- you need new ballast.
water drips out a drain hole and onto ballast
When you see the technology differances made since car was built and how much brighter new bulbs are (they lose lumens with age/2000 hours use)
you will say `thats the best 60 bucks I have spent on the car!
Old Mar 24, 2013 | 01:21 PM
5th Gear
I wanna thank everyone on this post, you all were a big people and i have ordered the kit from hidextra.com! Thanks again guys!
Old Mar 24, 2013 | 01:23 PM
5th Gear
I wanna thank everyone on this post, you all were a big help and i have ordered the kit from hidextra.com! Thanks again guys!
I will definately be checkin out your site in the future as I have recently purchased my first Acura!
Old Mar 27, 2013 | 09:32 AM
fog80's Avatar
I just had the same problem and bought a pair of phillips replacement bulbs from amazon. The ballast for the HID in my 02-tls is sealed well and there was no moisture issue.
Had been riding on the original bulbs, huge difference in visibility.
Old Mar 27, 2013 | 10:14 AM
cazio's Avatar
oops is that your face?
sounds like the ballast to me but try swapping the bulb from the side that works first, if it still doesn't work I'd bet on the ballast
Old Mar 30, 2013 | 03:50 AM
NkBenzon's Avatar
You sure it's the bulb? Because if it was the bulb it wouldn't even come on... My Acura does the same thing it flickers a bit then shuts off and it was just a bad ballast.. Up to you doe, good luck!
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
