HID lights issue? Acting weird
hi there:
i'd need help for my 03 TLS. the left headlight got wet about 2mos ago, replaced the headlight (not the bulb at that time). then the Bulb starts acting weird such as working, no working, right color, purple color, and etc.. just bought a pair of new 4300k light bulb (non-oem). Now, sometimes the bulb on the left is not working and sometimes on the right, then i'd need to turn them off and turn on ago, then it seems fine.
the problem is the one on my right was working just fine, but after changing both light bulbs, then they start acting weird.
-is there something else i'd need to change?
thank you so much
Alex
thank you so much
Alex
you need a new hid `kit`--try www.hidextra.com for amazing deals
you can buy the 2 ballast and 2 ignitiors without bulbs,,or as a package for $59!
worth having spare bulbs in my opinion
aftermarket is the way to go on this problem
crud is growing inside your ballast, resistance is changing,,, purple color is bulb age death
install this kit and the problems all go away
mada51589
Jan 9, 2025 04:40 PM
