HID headlight problem
Old Nov 16, 2007 | 06:44 PM
bricud's Avatar
Unhappy HID headlight problem
I have a 2002 TL type s with one headlight that comes on for a split second and then stays off. Is there a way to determine which component is bad? I understand there are a number of modules/boards associated with each headlight. Could I just swap parts from the other side without worrying about damaging good parts to find out the problem. Any help would be appreciated.
Bricud
Old Nov 16, 2007 | 07:37 PM
azn_xxxd's Avatar
.a BUM with SMG...
did you change the bulb or think back som one change ur bulb ? , cuz man , i had a same problem lik urs. My uncle swaped his bulb(Lexus) and put this bulb into my TL 03 , it stays on for like 5 seconds or some and then turns off by itself. Check the bulbs again and make sure they are clear and no dust at the bottom. Hope it help !
Old Nov 16, 2007 | 08:05 PM
bricud's Avatar
As a matter of fact, I just bought the car that the previous owner said he changed that bulb. Maybe the wrong one. I will swap bulbs before going any further. thanks.
Old Nov 16, 2007 | 08:49 PM
01tl4tl's Avatar
If it has the correct new bulb- and they should always be replaced in pairs- and it went out after a week- its most likely water in the ballest burned that out
very common prob
You can swap all the parts without concern
Old Nov 16, 2007 | 08:54 PM
Rsoetidjo's Avatar
Rich
Try swap the bulb to the other side.
Always use latex glove when you handle bulbs
Old Nov 19, 2007 | 08:10 PM
wr3nch's Avatar
6th Gear
it could be your bulb , wiring harnes from bulb to inverter, or inverter. if you have the time and tools , try removing the bulb from the good side first, if it doesnt work try the wire harnes from bulb to inverter is not that long , for last , ill try swap'n the inverter. make sure that the fuse under hood fuse box is good. showuld be head light low left or right. only fuse , bulb, wire , or inverter the cause of this problem.
Old Nov 19, 2007 | 08:34 PM
BIGJOHN713's Avatar
SSM.TL.4RM.TX
you just better hope it isnt the ballast because those things can get expensive
tman570
Jun 11, 2019 07:56 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Silverstead1
Sep 17, 2015 06:45 AM
JnC
Sep 11, 2015 06:06 AM
voigt
Sep 2, 2015 10:44 PM
