HID conversion kits
Old Dec 6, 2006 | 08:58 PM
muddanas's Avatar
HID conversion kits
I have a '99 TL and my HID light on the passenger side stopped working. It first was flickering and I later found out the fuse blew out. After I put a new fuse in the HID light looked very dim so I took it to the dealer and had them replace the bulb. This worked for about a month and then the fuse blew again. I replaced the fuse and the light now works intermittently and then the fuse blows again. The dealer says its the inverter and says it'll cost $700 to fix it!!! So I looked on ebay and its cheaper to buy an HID conversion kit for about $200-$300 dollars. I'm guessing another $200 to get it installed by someone. Does anyone think this possible? Or has anyone had the same problem as me and had it fixed for a cheaper price?
Old Dec 6, 2006 | 09:22 PM
fsttyms1's Avatar
you can do it yourself. Its very easy. Look into just buying 1 inverter. Used or new. If your wanting to check out our vendor Excelerate, he sells HID kits
Old Dec 24, 2006 | 01:56 PM
acura99's Avatar
wait question, i had kinda the same problem with my passenger HID..all i have to do is change the fuse? and it will work? becasue currently i have no light on the side, and i need a light..
Old Dec 24, 2006 | 03:39 PM
fsttyms1's Avatar
No. His problem was with the inverter. Yours will probably turn out to be similar, either bulb or inverter
Old Jan 7, 2007 | 01:29 AM
DIRTYJOHN's Avatar
I bought a ds2 kit for 140 on ebay.. plug and play.. took me 5 minute to install ...
Jul 16, 2017 07:33 AM
rhdune16
Sep 28, 2015 11:31 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
