HELPP stearing feels lose and car makes sounds
Old Mar 1, 2013 | 11:12 AM
Adam Elmezaen's Avatar
8th Gear
have a 02 tlp and when i turn left or right the car sounds like when you run over the wake up strips on the sides of the high way and the car steering feel like it dosnt wanna turn some times steering is normal some times it feels like im driving my truck just replaced my front rotors and pads
Old Mar 1, 2013 | 01:05 PM
8th Gear
anyone?
Old Mar 1, 2013 | 04:05 PM
TLer trash's Avatar
Your description is a little vague, but I think you should have a professional look at it. My guesses would be wheel bearing(s), c.v. axle, something you left loose when you did the brakes, ....?
Old Mar 1, 2013 | 04:11 PM
3.2TLc's Avatar
Was it doing this before ya replaced the brakes ?
If not, make sure that the wheels lugs are properly torqued.
If it was, then you're going to need to check your steering components. Assuming that the pump and belt are ok, look at the tie rod ends first....then the rack itself.
Old Mar 1, 2013 | 04:20 PM
8th Gear
i had my usual shop do the breaks and it was makeing the sound befor but not as bad.. so i should start with tie rods?
Old Mar 1, 2013 | 04:38 PM
3.2TLc's Avatar
How many miles are on the car ?
Did ya mention this problem to your "usual shop" ??? Tie rods are easy enough to check and replace if bad.
Also ya wanna make sure that ya don't have a bad rim or tire, as this could cause problems.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
tonio
Feb 5, 2019 05:43 PM
lland
Oct 4, 2015 04:47 PM
kuzdu
Sep 10, 2015 08:42 PM
