HELP Tailights wont indicate I'm Braking
My tailights do not indicate i am braking. I change the bulb and they do not power on when I press the brake. They power on only when i turn on the headlights. Someone help me, I bought new bulbs and they still wont turn on when i brake only when the headlights are on. ALso the middle brake on the back glass does work. Im afraid someone is going to hit me up the ass because they cannot tell im braking. I dont want to get pull over as well
Guys give me some ideas of what it might be
Did you replace the brake lamps with dual filament bulbs? Make sure you've used the correct bulb for BRAKE lights, and not TAIL LIGHTS... both require different bulbs (eg: they illuminate when turned on, and also appear brighter when the brakes are applied VS. bulbs that simply illuminate when the lights are turned on).
Originally Posted by bonknhead
If your tail lights and your center brake light are not working, check the fuse.
Originally Posted by Hova1222
My tailights do not indicate i am braking. <snip> ALso the middle brake on the back glass does work.
they were not working therefore i bought new bulbs thinking that was the problem. I changed all 4 bulbs. And the bulb number was 7443 for all 4. That was the number each bulb had when i took them out. I painted my brake caliper last week but i know that has nothing to do with it. I really dont know why is it doing this. ill keep u guys posted im going to my fathers shop tomorrow and try to figure out wat is going on
here you go
Originally Posted by bkzjimmy
follow the brake pedal up to the switch. press the brake with one hand then press the button on the brakeswitch with one finger and let it pop out. it works for me every time.
Jul 16, 2017 07:33 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
