HeLp PlEaSe !!!!
Old Mar 9, 2014 | 10:13 AM
KatelynJordan Roach's Avatar
9th Gear
HeLp PlEaSe !!!!
hey guys i was at a red light and the 02 tl just died and wont crank over acts like it wants to but just wont i have had no problems with it till yesturday please give me some ideas Thanks
Old Mar 9, 2014 | 10:56 AM
9th Gear
any body have any ideas
Old Mar 9, 2014 | 11:06 AM
could be lots of things.
battery? starter? clogged IACV? CLogged EGR?
Old Mar 9, 2014 | 11:15 AM
Nicks2001tl's Avatar
I would start with the battery.
Old Mar 9, 2014 | 11:28 AM
3.2TLc's Avatar
Is the CEL on ? Anything else unusual ? Tried jumping it yet ?
Maybe the alternator or bad ground causing battery drain....try cleaning the terminals.
Old Mar 9, 2014 | 03:50 PM
Skirmich's Avatar
Tough one.. Check Fuses? Main Relay?
Old Mar 9, 2014 | 05:39 PM
3.2TLc's Avatar
Yeah, something either electrical or fuel related ? Is the fuel pump activating ?
Old Mar 9, 2014 | 06:36 PM
fsttyms1's Avatar
So to clarify, the car cranks but doesnt actually start, or you turn the key and nothing happens?
Old Mar 9, 2014 | 06:57 PM
Skirmich's Avatar
^ If that check for the Key icon in the dashboard, Should light up if it doesn't turn off then there is an issue with the immobilizer.
Old Mar 9, 2014 | 07:08 PM
9th Gear
ok i got it home it did need a new battery now she just sits thir and cranks over but no start i did have a crank sensor code would that make it not start up and how hard is it to put a crank sensor in
Old Mar 9, 2014 | 07:10 PM
9th Gear
and the Key icon in the dashboard does light up
Old Mar 9, 2014 | 07:27 PM
9th Gear
please any thing will help just sits thir and cranks over normally but no start
Old Mar 9, 2014 | 09:10 PM
ErickUa5's Avatar
Mr.Helpful Diagram
May have a jumped timing belt, Can you try getting it on video ?
looking at the dash lights wait for the 3 beeps then crank it while recording.
Old Mar 10, 2014 | 08:26 AM
Starter?
