Help with finding out whats wrong-alarm
Old May 21, 2011 | 02:02 AM
urmomiscute's Avatar
3rd Gear
Exclamation Help with finding out whats wrong-alarm
HI,
I just got a 99 TL from a friend. Haven't had too much experience with a TL so here are the symptoms:
1) All except the driver's lock works with the remote control nor the master lock control. (But the passenger side incl. front&back fine when locking with the key on the passenger side)
2) Trunk SOMETIMES works with the remote
3) The lock/arm beep SOMETIMES work
4) When unlocking with the remote, SOMETIMES the car would relock on the first time
Could all these be connected and caused by one bad part? What possible parts do I look into? Or I should just get a after market alarm.....
Old May 21, 2011 | 11:22 PM
totaledTL's Avatar
Make sure your battery is good. Have it tested. Have you tried disconnecting it for a few min.?
Old May 22, 2011 | 01:01 AM
3rd Gear
i just went out and cleaned the battery. same thing though...
Old May 22, 2011 | 01:20 AM
Karanx7's Avatar
Unregistered Member
Yea I doubt it all went bad separately, as none of those are common problems. It's most likely one or two things causing the problems.
It's weird that stuff works "sometimes." Try to find what conditions make it work, and what doesn't. Or is it just random?
Old May 22, 2011 | 02:20 AM
3rd Gear
well...this annoy the @#$ out of me..
i know that the lock actuator on all except the driver's door may be down? BUT both the front and rear doors on the passenger side WORKS with the key on the front passenger door!!!!
Even with the trunk...it works just fine but not with the remote...
Old May 22, 2011 | 04:37 PM
totaledTL's Avatar
That won't do squat... need tight clean connections to a good (tested if unsure) battery. Does it have removable caps to chk. the fluid level?
baelim
May 10, 2018 09:53 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
BIGxRED
Oct 19, 2015 10:47 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
eastcoastguy
Sep 23, 2015 06:29 AM
