hello first timer here, need help.
Old Jan 4, 2011 | 06:36 PM
wcarboni's Avatar
I have a 2003 tl 3.2 type s all of the sudden the heated seats have stopped working, both of them, check and replaced the fuse (20A) checked underseat plugs they look good, dwhat else could be the problem?? any help on this matter would be greatly appreciated, its cold here.
Old Jan 4, 2011 | 06:49 PM
gold2003tl (90)'s Avatar
2003 TL-p
it is a common problem to have them fail, there is the DIY on how to fix them. it does require ripping the seats apart.
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-heated-seat-successed-cost-only-%243-607220/
Old Jan 4, 2011 | 10:24 PM
finalcross's Avatar
Yep mine never worked since I got the car, but the back heater works. I also saw a DIY on youtube a while ago.
Old Jan 5, 2011 | 01:53 AM
01tl4tl's Avatar
we have a good diy- I trust ziners~
the passenger only gets bottem heat due to side airbag and passenger detection sensor system
driver gets lumbar and bottem sections
use of High heat on a constant basis is wrong- warm them on High then Low for duration
Old Jan 5, 2011 | 01:55 AM
01tl4tl's Avatar
was the fuse ok- tested with different fuse?
and the relay ok- swapped with a matching relay?
one section to fail is normal, but loss of both seats suddenly points to a switch or main power issue
switches light up?
Old Jan 5, 2011 | 06:28 AM
wcarboni's Avatar
yes both switches light. Is there a relay involved somewhere, how can I get a wiring diagram for it?
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
dirleton
Sep 25, 2015 12:25 AM
mellsonnj
Sep 24, 2015 04:42 PM
