Headlight Washer Mod?
Old Jan 26, 2006 | 11:12 PM
jinharry's Avatar
Has anyone come up with a mod to add a headlight washer (like the BMW cold weather package)?
Here in Colorado we get a lot of mud/slush on the headlights during the winter/spring which means you have to stop every now and then at night to clean the headlights if you want to see (old eyes need lots of light). I was thinking about adding a second pump and reservoir (if there's room) along with nozzles from some car that has the right spray angle and pattern. I also planned to run the hose such that it gets heated by the engine block.
Has anybody already done this?
Old Jan 26, 2006 | 11:15 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
That sounds like quite a bit of work, but I'd like to see it done.
Old Jan 27, 2006 | 07:11 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
the heated washer is ideal. buick has heated spray nozzles now that spray something around 105degreesF water on the windshield to melt ice. i dunno why nobody did it sooner.
SSTS
Old Jan 27, 2006 | 08:42 AM
demolition_x's Avatar
Agean Blue Bishes
well most cars after they are warmed up the windshield washer fluids heats up.
i notice in my car it will steam a little.
doesn't really do any good since the heater probably already melted the ice.
headlight washers are just a pain. my a4 had them before and it really didn't help. it had a seperate pump and the pumps and the sprayer heads always broke.
Old Jan 27, 2006 | 09:15 AM
RickRoush03's Avatar
RickRoush03
why heat it, just get like rain-x washer fluid or equivalent, i don't wait for the ice to melt, i just spray that stuff on the windshield and in like 5sec i am golden. i think the mod may be easy if you plan it right, i'd start with getting the devices, i'd tap into the existing washer bottle we already have. may be more work then its worth though?
Old Jan 27, 2006 | 03:58 PM
03CoupeV6's Avatar
I've had the washer fluid freeze in my car before and not spray until the outside temperature was above freezing for an extended period of time, so engine heat really isn't that effective in heating the fluid in the reserve. The companys that heat it must have another trick.
Old Jan 27, 2006 | 06:13 PM
fsttyms1's Avatar
Ive thought about it a few times. It would be a Very easy mod. All you would need is 2 washer nozels, and a 2nd pump. the oem tank has a spot for 2 pumps already but is only using 1. Then you would just need to wire it up so that you could control the spray with your windshield washers or seperatly
Old Jan 27, 2006 | 06:22 PM
ou sig's Avatar
Boomer SOONER
ya and mount the sprayers somehow
Old Jan 27, 2006 | 11:29 PM
RickRoush03
what kind of washer fluid are you using, being here in upstate NY its gotten low teens and i have used prestone and rain-x washer fluid with no problems.
Old Jan 27, 2006 | 11:55 PM
Agean Blue Bishes
yea you can get these for your washers...
it would be way cool
hope you sensed my sarcasim
Old Feb 4, 2006 | 07:39 PM
Bareback's Avatar
TL = Tranny Lubrication
Like this?
Old Feb 5, 2006 | 01:30 PM
jinharry's Avatar
Heated Windshield Wiper Fluid
That looks like it might do the trick! Is it available in the U.S.?
Old Feb 5, 2006 | 03:05 PM
MikePA's Avatar
Here's a link to a different model.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
Mr.Tea
Oct 2, 2015 10:32 PM
