headlight issue
Old Nov 5, 2007 | 09:37 AM
whiteacura02's Avatar
6th Gear
headlight issue
I have a 2002 tls with hid. I recently changed out my headlight assembly for both lights and also the bulbs. the bulbs were changed to 6000k . The left light works good but the right light has a reflection in the beam making one area on the road appear alot brighter than the other areas. It is a curved reflection probably off an interior light curvature.
I have changed the height of the lights but not the right to left aiming. Will that fix it or is there another problem?
Old Nov 5, 2007 | 09:53 AM
fsttyms1's Avatar
Make sure the bulb is installed correctly and seated properly
Old Nov 5, 2007 | 10:05 AM
01tl4tl's Avatar
agree-
if you used D2S they dont have the locking detent the factory bulbs have. Its easy to get the bulb installed a little turned and that will mess you up
Remove bulb- noting location of the extenal rod- I believe it goes straight up when correctly installed
Do not twist the bulbs in the socket- straight in and clamp in place
How is the spring clamp that holds the bulb in place?
I had to adjust the height when I replaced entire housing- and a little more side-side adjust wouldnt hurt to set it to my liking
Old Nov 5, 2007 | 07:19 PM
6th Gear
i have taken out and put the bulb with many tries, this did not fix the problem.
I can fully wiggle the bulb in place in all direction moving the length and width of the reflection but it will not disappear
Is there anything else it could be
Old Nov 6, 2007 | 11:33 PM
sickstyle123's Avatar
2000 tl
what do you think about the change to 6000k?
Old Nov 7, 2007 | 12:06 AM
Rsoetidjo's Avatar
Rich
Me personally like the 4300K or 5000K.
Put out more lights/lumes.
I have the 6000K on my bike and looks too blue for me
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
acuraST
Sep 17, 2015 02:31 AM
JnC
Sep 11, 2015 06:06 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
