Headlight flickering Problem
Hey Guys I need some help. My passenger side headlight flickers and then sometimes goes out. This mostly happens when I turn, but it has been happening recently when just going straight. I might hit a little bump and the headlight flickers then goes out.
Any ideas?
Thanks for the help!
Any ideas?
Interesting... I thought I noticed the same issue when turning, but wasn't sure if it was just my eyes playing tricks on me.
Passenger side, only when turning. I'm going to check the connections now to make sure they are in tightly.
ukemasta (11-16-2012)
Yeah, check the connections. It could be condensation starting to kill your ballast or ignitor. Look for signs of moisture. Be careful not to touch the bulbs unless you have latex gloves on....you may want to try swapping sides to move the problem.
If moisture is present, consider replacement with newer style units which are less expensive.
this is the death warning of the hid system,,same as mine did
get a new `kit` with 2 modern ballast- ignitors and bulbs for only $59!!
www.hidextra.com is one of our sponsors
there are even 10% coupons around
suggest 5000K bulbs for closest to stock with a little more blue to pick out road markings
good parts- many of us use them,,they sell on ebay too,,they sell to other resellers who mark the price up
if a part happens to fail- a phone call gets an immediate replacement,,they are in California
easy diy, a little thinking and custom remote mounting of ballast may apply~
its been well covered in threads on headlights
the stock hid system is from the time of the dinosaurs
new ones are mini sized,,epoxy sealed electronics, water tight connectors on the wires etc
dont worry--your ballast will quit soon enough
always replace headlight bulbs in pairs,,the color and brightness will be way different
mine went a long time before failure
had new kaixen bulbs,,finally no more light,,kit fixed the prob
past history of moisture in headlight housing, replaced housings and bulbs 2 years before ballast failure, and it did have crud inside
I always mention replace bulbs in pairs- so noobs get info they need
So if I buy that HID kit. is it just plug and go? Or do I have to connect the new ballast to the battery? Did this happen to you? Thats why you replaced?
my ballast died
after flikking switch several times to get light restored while driving, having it run one side off -then the other,= time for the kit,
new bulbs in there 2 years already were not the answer
the hidextra kit is almost plug and play
you cut the connector to ballast off and splice in the 2 new wires (per ballast)
then some zip ties can be used to remote mount ballast to outside of the frame rail
loop the extra length of wire from new ballast to bulb- underneath the light housing
slide it all together like a puzzle--its easy
the real trick is knowing about the hidden screw from rear bumper cover edge to fender
turn wheels for access- its vertical
http://www.hidextra.com/9005/6000k/
Thanks for the reply. So is 5000k or 6000k more blue? Also, Is this the kit you were talking about? plug and go, with the slicing of the 2 wires per ballast? is the splicing wire the wire that connects to the battery?
stick with 5000k bulbs
I have run them side by side on my TL and 6 is WAY more blue,
and and a lot less white that you need to pick out objects on the road!!
otherwise thats the right kit
the leads to cut are for the old ballast at its connector to ballast
all power runs thru relays now,not direct to battery
You can buy a connector to match the ones on the new ballast wires- they dont provide ones for car side of plug but any parts store can hook you up
then no splice required- crimp install end connector and slide them together- wrap with electrical tape or shrink wrap tape if you have any
my ballast died
hey 01tl4tl,
was this your new ballast from hidextra or the old original one? I had an issue last night where I had to flick a few times to get the bulbs to ignite. I went through the carwash so I thought it was that but it was fine right after. Only after I stopped somewhere, then it didn't want to turn on. First both, then fine. Next stop, one didn't want to come on but after several flicks it came on. Thereafter, both were fine. Haven't tried today yet.
the oe ballast had suffered moisture in the headlights and eventually did the flick to turn on--dies while driving stuff,,
since install of hidextra kit no more problem
their regular size ballast is smaller than a deck of cards,,the oe ballast about the size and weight of a brick
mine are ~racer style~ mounted to the outer frame rail,,thats a long zip tie or 3 together, and some gorilla tape
you can use their bracket and mount in several ways-locations too
hm. curses. this is my new kit from hidextra too. I wonder if it's some grounding issue that you mentioned in another post. It hasn't happened again yet but I'll see what happens when it rains. I guess this is what I get for going against your advice and mounting it back into the same place in the assembly.
run a ground wire from new ballast to a screw or bolt on the frame area
ignore my advice at your own risk....made enough mistakes to share insight
SAME thing happened to me .. i installed my new kit last year, then about 3 weeks later the passenger side went out .. the fog lights work fine, the driver side is working great, its just the passenger side thats dead! .. im so frustrated with my headlights ..
do u think running a ground wire would work???
Hey Duran492, need you ask ? If 01tl4tl advised this.....I'm sure it was from experience !....'nuff said.
duran492 (12-04-2012)
remove 1 screw holding the cover on ballast,,need a very small connector to fit
attach your ground wire there
are you using the double stick tape under ballast--between it and frame?
or you may have an actual ballast failure,,things happen~ bad connector or weak solder etc
hidextra is really good about warranty for a year (maybe longer if you ask nice)
or will do super cheap on a replacement ballast if needed
mention acurazine when you call
Well here's what happened. I did call hid and got a replacement ballast because of the current problem in Janurary. i swapped ballasts and it still was a problem. So I put the other one away. Now 11 months later, I swapped ballasts again and then both lights worked. I drove around for 15 minutes and no problem. Once I shut the car off and flipped the lights off, the driver side went out now. But the passenger works. FML right. Haha. I'm friggin goin crazy here.
so when i left for work a little bit ago .. i flicked on my headlights and now only the driver works again .. i flickered the headlight switch about 3 times and they both go on now .. when i got to work, i turned them off and tried turning them back on and only the driver is on .. so there must be a wiring or that grounding problem . . . .
tman570
06-11-2019 07:56 AM
