Headlight & cluster problem please help!!!
Hey guys, I've been having this problem for a weeek now.. & can't find whats wrong with my headlights. First both headlights would work then the right one will not work. It goes on and off, on and off. Now the right one doesnt work at all. I checked if the bulbs are blown but their not. Helppp please!!
Also another problem is...my cluster hasn't been working for a whole month now. My rpm, mph, gas, mileage doesnt work at all except the temp... the temperature would always jump to hot then it would bounce up and down when it wants too...
problem 1 is needs new hid kit, ballast are dying probably from age and or moisture gets inside light housing
www.hidextra.com $59 kit has all we need
get 5000k bulbs
prob 2 is likely bad ground wires
ck all the small ones from frame to engine and main battery ground cable
those are old and may all need replacement
ck relay and fuses for dash,,may have bad soldering underneath
get 5000k bulbs
brandnewcolony
Sep 12, 2015 10:39 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
