headlight aiming problem
i was trying to adjust my headlights but i wasn't able to adjust passenger side, it just not go up but it goes down and when i try to move it up it stops at certain point which puts all light output about 6 ft on road whereas driver side works perfect as adjustment goes. please help!
the bolts for the housing are there- car been in an accident?
look if the gears are really turning the final adjuster
Maybe the bulb is in upside down?-- if those were replaced
iirc there is a little bit of play in the bolt holes for the housing- loosen bolts and and move the entire thing up a tick,, see if that fixes it
You may be at the end of the adjustment range? does it stop turning or what?
I suspect the bulb was installed upside down- its easy to do and if you were not paying attention to the external wire when removed--not know which way it goes back in
Also there is a reflector plate that goes over the bulb and attached to one of the tiny screws for the retainer spring arm
If thats missing or fell inside housing--result is light cast onto the ground
DIY or take it back to him
take a close look from outside the lights for any differance in install
the bolt on the middle gear does turn with the adjuster- iirc it holds the gear on~
the adjustment is the method I gave you- from the owner book
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
