Headlight adjustment?
Old Apr 7, 2007 | 07:20 PM
dharhigh1's Avatar
7th Gear
I have a 99Tl and I need to adjust my driver side headlight.
The low beam seems to be the problem.
Can someone post a picture that would show the adjusting screws or mechanism for this?
Thanks in advance,
Dan
Old Apr 7, 2007 | 11:27 PM
Hockeyman's Avatar
slobalt defender
there should be a bolt in between the high beams and low beams, it's a 10mm and you just turn it one way or the other. Should be the only bolt visable if your looking at the back of the housing.
Old Apr 8, 2007 | 12:51 AM
2003blacktl's Avatar
Is it any similar to headlight adjustment for a 2003 TL? Mine need tweaked a little.
Old Sep 27, 2007 | 12:15 AM
Lo Pan's Avatar
B A N N E D
i adjusted that bolt, but doesnt seem to adjust at all
Old Sep 27, 2007 | 09:29 AM
01tl4tl's Avatar
check for the letter U or D and go opposite direction- up makes the beam go down
there are super fine teeth on a plastic wheel- thats what you are adjusting so it may take a while to go very far
Just put new housings in my car, so its pull up to the garage door at night and keep turning!
If it wont turn- you're at limit of wrong direction!
hashbrown
Feb 18, 2022 11:20 AM
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
