headdash warning light !!
Old Jun 17, 2013 | 07:32 PM
juniorlokz's Avatar
My maint required light is on, I have an obd-ll scanner but when I connect it, it tells me the (mil) is off does anybody know what that is ??
Old Jun 17, 2013 | 07:53 PM
Skirmich's Avatar
MIL stands for "Malfunction Indicator Light" so its basically saying you dont have a Check Engine ON light?
Old Jun 17, 2013 | 08:07 PM
Karanx7's Avatar
Unregistered Member
Maintenance required light is just a oil change reminder light. Start's flashing when you start the car at 5000 miles. Stays on when you hit 7500 miles.
Get your oil changed, and remind them to reset the light. Or do it yourself.
Old Jun 18, 2013 | 12:24 AM
Skirmich's Avatar
The OBDII port should not give a hint of the Maintenance Required Light, Also that is not even connected to the ECU its part of the dashboard system.
MIL in this case on the OBDII port its for the Malfunction Indicator Light which in MANYYY scanners means the Check Engine Light.
mada51589
Jan 9, 2025 04:40 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Rob144
Sep 21, 2015 08:18 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
