H.I.D light flicker on/off fix.
Old Aug 6, 2012 | 04:37 PM
lvlarkeo's Avatar
Smile H.I.D light flicker on/off fix.
OK so this fix worked for me nothing crazy.I just changed bulbs and that wasn't the problem I switched igniters to find that was why my light would give me problems turning off randomly and not turning back on unless I toggled the light switch a few times...what I did was unplug my igniter spray the white connector and bulb connector with a electrical connector cleaner. let it dry then put a lil bit of dielectric grease on both connectors. I also cleaned the hid connection port mounted on the back of the lamp. plugged everything back up and worked great so far! all I need now are new bulbs I got factory bulbs in right now. planing on getting 5000k Phillips. i do understand this isnt going to bring igniters back from the dead but worh a try if your light flickers on/off randomly.
Old Aug 6, 2012 | 07:17 PM
01tl4tl's Avatar
once you get that prob you liklely had moisture in lens issues for a while
replace the entire hid system for 59 us dollars! www.hidextra.com
bulbs ballast ignitors for both sides included
then you are done with the problem
Ol'Dave
Sep 5, 2020 02:56 PM
tman570
Jun 11, 2019 07:56 AM
VA2000TL
Oct 2, 2015 08:26 AM
Rob144
Sep 21, 2015 08:18 AM
Phambam12
Sep 6, 2015 06:57 PM
