Glovebox Rattle
Old Aug 21, 2010 | 09:52 AM
Glovebox Rattle
Discovered a new noise recently.
Only in turns, sounds like something sliding/rolling across the glovebox. Nothing in it except the owner's manual.
Old Aug 21, 2010 | 10:40 AM
hANDYcaptd's Avatar
It's the Halladay season!
More detail? Does it happen in all turns? Or only fast, or only slow. Does it make noise when you turn the wheel at a standstill?
Old Aug 21, 2010 | 11:03 AM
Pretty much all turns. Haven't tried just turning the wheel sitting still. Sounds like something inside the dash in the glovebox area is loose and sliding around.
Old Aug 21, 2010 | 12:33 PM
01tl4tl's Avatar
must be time to change the cabin air filter-
glovebox is removed as part of that diy so anything in or behind it should be found
Old Aug 21, 2010 | 12:35 PM
First car I've had with a cabin filter....forgot about that. I'll have to look into it.
Old Aug 21, 2010 | 10:24 PM
totaledTL's Avatar
Maybe something fell down in the plenum and is causing the noise. If you've had the car a while & never replaced the filters get ready, they're probably nasty.
Old Aug 22, 2010 | 04:21 PM
Had my wife in the car with me today, she said when the reattle happened, she felt the noise in her feet. So, maybe something under the passenger floor? Is there a "pocket" under the floor pan? Where something could be moving around?
Old Aug 22, 2010 | 08:06 PM
01tl4tl's Avatar
ck under seat for missing golf balls?
who are you going to believe--us on the other end of a modem,
or your spouse the diagnostic expert?
Old Aug 22, 2010 | 08:07 PM
01tl4tl's Avatar
at her feet would be the cabin air filter-
you cant believe what gets in there!!
marcelft
Jul 10, 2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
