Gas pedal not working at times
Old Jun 7, 2010 | 10:57 AM
irishTL's Avatar
I have what I think is a very strange issue. When I first start up my '01 TL, the gas pedal works fine at first, then within a few seconds, it fails to work at all; it is as if the engine is not even on, yet it is running. It will go back and forth between working and not working within about the first half minute of being turned on, then it will usually work fine. I changed all the spark plugs out this weekend, but the issue remains as it was. I am pretty baffled about this issue. Anyone have any ideas?
Old Jun 7, 2010 | 11:56 AM
myisanog's Avatar
my car used to do that . kind of . i would gas it but it doesnt go . the hose connected to my fuel filter was leaking but its ok now
Old Jun 7, 2010 | 12:37 PM
irishTL's Avatar
Was your car a TL? The reason I ask is because I've read that the TL does not have a fuel filter.
Old Jun 7, 2010 | 02:36 PM
myisanog's Avatar
95 DC RS . was a long time ago
Old Jun 7, 2010 | 03:28 PM
webmastir's Avatar
2003 TL
Originally Posted by irishTL
..because I've read that the TL does not have a fuel filter.
Not sure where you read that . Fuel Filter is located in fuel tank, attached to fuel pump.
Old Jun 7, 2010 | 03:57 PM
01tl4tl's Avatar
its a sock on the fuel pump in the tank- not replaced in normal use
remove the top plastic engine cover and ck the throttle mechanism
springs, cables and the rest
Old Jun 7, 2010 | 04:11 PM
fsttyms1's Avatar
Explain gas pedal not working. LIke you push it and the car wont rev?
Old Jun 7, 2010 | 04:30 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Are you sure you're not driving a Toyota?
Old Jun 7, 2010 | 09:01 PM
hANDYcaptd's Avatar
It's the Halladay season!
Wouldn't that be the opposite of his problem?.....
Old Jun 7, 2010 | 09:16 PM
irishTL's Avatar
After I start it up, I hit the gas and it revs the engine as normal. Within a few seconds, pressing on the gas pedal fails to rev the engine at all; it is as if the engine is not even running, yet it is running. It does absolutely nothing at all. That lasts for just a few seconds, then it works as normal. Sometimes that process will occur again immediately afterward, but within a few seconds it operates as normal.
Old Jun 7, 2010 | 10:46 PM
irishTL's Avatar
Pretty sure it was on here somewhere, though I can't find it at the moment. It did sound very strange to me.
Old Jun 8, 2010 | 11:35 AM
01tl4tl's Avatar
see my post from yesterday- fuel filter is a sock on the pump inside the tank
Old Jun 8, 2010 | 12:17 PM
myisanog's Avatar
it just doesnt need to be maintenanced like older cars
Old Jun 8, 2010 | 12:24 PM
NSXNEXT's Avatar
Sounds like the throttle plate is sticking.
With the engine running and in park, pop the hood and look at the back of the throttle body for movement while someome steps on the gas. You should see a brass gear turning everytime they step on the gas. If it doesn't move, it's because the throttle plate is stuck.
Old Jun 8, 2010 | 05:08 PM
irishTL's Avatar
Hmm, sounds like a possibility. I don't recognize anything in that diagram, though. Can you give me a different description of where it is on the engine?
Old Jun 8, 2010 | 05:09 PM
irishTL's Avatar
Gotcha. Thank you.
Old Jun 14, 2010 | 01:28 PM
irishTL's Avatar
Bump.
Old Jun 14, 2010 | 01:43 PM
NSXNEXT's Avatar
Look for the two cable going to the throttle body.
Looking at my diagram, find part 1 (right side of image). Now just to the left of that is the throttle body.
Standing in front of the car look on the back side of it for two cables going into it. Those are the throttle cables. Make sure they are moving freely when someone presses on the accelerator.
Old Jun 14, 2010 | 01:52 PM
irishTL's Avatar
Sounds good; I'll try that. Thanks for your help!
mada51589
Jan 9, 2025 04:40 PM
acurajj
Sep 19, 2015 03:47 PM
kuzdu
Sep 10, 2015 08:42 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
