!! Gas mileage !!
~~~ SKY'S THE LIMIT ~~~
!! Gas mileage !!
fuck guys--i cant win it seems !!!
so i had 18in rims on my TL in the summer and i was getting like 400miles to a full tank on the highway
now i put on 16in factory accord steelies on for the fall till i store it for the winter and im getting fuckin terrible gas mileage
i have no idea whats good here----this fuckin sucks bad !!
i did every possible thing i can think of a few months ago to maintain it
plugs, ( NGK ), cleaned the throttle body and EGR passage, correct air pressure, cleaned air filter
what do you guys think can be wrong here--what else can i do ???
THANKS IN ADVANCE !!
honestley i drive normal----i mean i dont beat my shit
light turns green and i ease on the gas pedal----i dont fuckin gun it from light to light on the city roads
and on the highway---i ALWAYS use cruise control---and even on the city roads where i can i use cruise control
and the tire pressure is set at 38psi ALL AROUND
have you weighed the tire sets--is there a major differance?
you can ck the size vs speedo change with a calculator on www.tirerack.com and other sites
going from the stock 205 60 16, to 225-40-18s actually fixed my slightly fast reading speedo
ckd today against 3 different roadside radar displays,,spot on!
seafoamed it lately?
the new brakes are not dragging? calipers are working right- not one stuck partially on?
leave a hose clamp loose when cleaning air filter? cover cracked and didnt notice?
Vac good? no vac loss at broken motor mount?
seafoamed it 4 days ago in the gas tank
brakes are not dragging----calipers are perfect
i have a cold air intake---and i cleaned the filter
and wud a broken motor mount really cause bad gas mileage to that extent ???
Gas. You change stations lately? Im not sure if winter blends are being rolled out but im sure its soon and that would cause it too.
Oh and i just got 250 miles to the half tank driving to rockford and back today cruise set at 80
FSTTYMS 1 ^^
have not changed situations at all---i drive the same way---day in day out !!
and i put 93 octane in my car ALWAYS !!
this is bugging the shit out of me guys !!!
Seems like im not the only one with bad gas mileage.. seems like everytime i get in my car i always have to fill up
. half a tank only lasts me about 3 days going to like work and back to my house. 7miles to work* my car takes all the money i have
A half tank only lasts you 42 miles...no way
Re did the math and its about 19 miles from home to school, school to work and back home.
38miles. 1.5 days roughly of doing that.
how would i test how many miles my tank gets? set it to trip b and reset the odometer? and just drive till its gets on E?
i always use cruise control every where i go also, usual speed i go is 40mph everywhere city or around 60-80 highway
fill tank to first shutoff of nozzle
reset trip
when down to 1/4 tank or less- refill to first click of nozzle
Helps to use same station and pump
now some basic math
miles driven divided by gallons needed to refill to same level at starting point
example 300 miles 15 gallons = 20mpg
reset trip
now some basic math
How many gallons is our tank? Just gonna wait till im near E, fill it up all the way, drive again till it hits E, do another run and average them out.
Tank 1 = X miles / tank gallon = miles 1
Tank 2 = X miles / tank gallon = miles 2
Miles 1 + miles 2 = X Miles / 2 = MPG Average
Oh and the tank is just over 17 gallons. Low fuel light usually comes on with about 3+- gallons left.
our cars are tuned to run min. 91 octane. id use nothing less as some people say u can see a drop in mpg by anything lower and also run the risk of messing something up..
there is no prob running to E, there is still gas in the tank at that indication
and lower,,as I learned
the low fuel light is to give you warning that `sometime today`,,within 50 miles as a conservative estimate, its time to get gas
the car is actually designed to run on 94, but the ecu can compensate for 91
anything lower causes several unseen problems and will not offset lost mpg for the 2 bucks a tank you saved
if a station has 87, it has 91,,use it or sell the TL
Well for me 87 costs me more to use than 91 costs. I get worse mileage with it, usually about 60 miles or so. That difference is more than the difference between 87 and 91. Also add up what you are saving at the pump between the 2. 3 bucks maybe? Its not worth it!
LOL thats the thing though... i cant tell which is better for me cause idk the mileage difference yet
If its mostly city driving the difference will be smaller, BUT you should still put in what the manufacturer recommends. Its what the car is optimized for. How much are you actually saving by putting in the cheaper stuff? Not much!
3.99 for 91 and happy its dropped from 4.29-4.49 !! for a gallon!! recently
Ca has its special extra bs added to the gas to get less mpg,, so we really take it
from both ends
but--- here its only 20 cents a gal price diff between 87 and 91,,
thats 3 dollars total more for a fillup from the low light ~15gal
hardly worth considering use of 87,,not like its a dollar a gal more
Take a few less trips you dont really need, or combine errands, avoid short trips.
program GPS with days errands for `the great circle route` to save even more fuel
anything to avoid the car running less than perfect is the plan
give up starbucks for a day (example)
from both ends
ck the owner book - 94 octane is what they designed the TL engine for.
thats why the gas cap door says 91 MINIMUM,,,minimum meaning `not less than`~
some states have 94, but not many I found, so 91 is the acceptable `minimum alternative` to the spec 94
Did you try cleaning the fuel injectors. dirty injectors can definitely give you bad gas mileage. and also I found that getting rid of the carbon buildup in the engine helps a lot. Seafoam treatment is pretty good. other than that I use about a tbs of ATF in each cylinder and it cleaned all the carbon out of my engine, my TL runs like it was new. sounds crazy but it works and it didn't hurt my O2 sensors. after you do any kind of tuneup to the engine the last thing to do is reset the ECU.
you cant compute on a refill to partial level--no way to get it same as before, guage always moves after you run the engine a minute
from first click of nozzle shutoff, drive 1/2 tank or more for decent accuracy, refill to first click
same station and pump gives best result
i just hit 65miles with 6-7 gallons and its about 1.5 notches from empty.. i cant be getting 9-10mpg
Does anyone else feel bad for Tony not getting this?
Fill up your gas tank. Drive it ~ 100 miles, fill it up again. That is how much gas your car uses to drive 100 miles, now do the math.
I blame the public school systems...
yes, the pumps in north america have an auto-shutoff system
when it stops the first time,,clicks OFF, stop fueling
It is possible to add more fuel to the tank, if you were getting on the freeway for a 400 mile trip you might `top off` the tank, but otherwise stop at the first click off
that will give you a measured place
do as said above but 200+ miles will give you a better `average` than 100
the guage means nothing especially when its low
Ill fill up my tank today with 91, drive 200 miles, fill it up and then average it out.
