FPR question
Old Oct 15, 2019 | 01:33 AM
Zafacon's Avatar
5th Gear
FPR question
If I change my FPR did I have to reprogram my computer or not. Thank you
Old Oct 15, 2019 | 05:38 AM
The first attachment below is from a CL service manual on how to change the FPR. The process should be similar to your 2000 TL. It does not specifically say the ECU has to be reprogramed as a result.
However, if your car is diagnosed as having 'heat soak' issues, as outlined in the second attachment, then yes, you should have the ECU replaced or reprogramed, as 01acls mentioned in your other thread in 2016.
Originally Posted by 01acls
Here i'll save you some time.
Check your fuel pressure regulator and see if it's Black Dot type. If not, replace with one that is.
If the car starts when engine is hot after a short stop after installing the black dot FPR, then you'll found the problem... Heatsoak.
The car is going to run rich at startup, rough idling when engine is still cold and warming up. You can live with it as is if it doesn't bother you or you can upgrade the ECM to match the FPR so the car runs as designed.
To upgrade the ECM it'll cost you $700-$1500 depending on emissions or non-emissions... new. The work around is to upgrade with a use 2001 ECM for less yhan a $100.
However, you will need to code the new ECM to ALL your keys and has to be done by the Dealership $200--$300.
Goodluck.
File Type: pdf
File Type: pdf
Chessie724
Mar 10, 2012 02:24 AM
Chill_Bill
1G TL Performance Parts & Modifications
May 16, 2009 01:02 PM
IranBT
Sep 3, 2006 03:59 PM
M1sta801
Aug 19, 2006 11:18 PM
rise
Technology
21
May 25, 2005 04:33 PM
