Found road hole .. :(
Okey, so catch the hole this morning...
Wheel is ok, expt bolt holes are scratched...
and the main shit is that 2 bolts gone plus 1 nut from 3rd ...
Was driving ~1km on 2 bolts...
As i remember bolts are going from another side of rotor, right? To change them, i just need to remove rotor?
I can buy any kind of 114.3?
Any recommendations for bolt ?
wait.. your saying it ripped 3 of you wheel studs off your hub assembly? if im hearing this correctly don't drive your car and fix asap. i would order a new hub assembly.. that one could be bent
It's the Halladay season!
114.3 is the bolt spacing, not size. I believe the studs are 12x1.5mm. You can get them at the dealer. They're not expensive at all, couple bucks. You shouldn't need to change the hub.
And yea, you have to remove the rotor to get to the hub assembly. From there, it's just hammering the stud out, or what's left of it.
Oh and pics of this CRATER??? It has to be a crater to break 3 studs...lol
And rim bent?
And rim bent?
Not sure, will try to find it later, it was on the highway.
rim looks ok so far, but had no time to check it closer. Since rim looks ok, what i thinking is that maybe nuts has loose, or maybe someone was trying to steal my rims... ?i was too lazy to park my car last night.... hahaha...
6G TLX-S
Agree. With the impact so severe to rip off the wheel studs, make sure you also check the suspension for damages, as well as an alignment job.
Received 1,080 Likes
$120 gets you a new hub and the studs.
Part # 42200-S87-C52 BEARING ASSY., RR. HUB UNIT
