fog light out..need knowledge
Old May 4, 2009 | 01:11 AM
JterrorC's Avatar
Always a Honda =Þ
one fog light doesnt turn on....bulb is mint.....fuse is fine....what could it be??... fyi its spliced into the corner light...which reminds me....what could i do to make the corner lights brighter??
Old May 4, 2009 | 06:40 AM
totaledTL's Avatar
Chk. fuse w/ meter to make sure it's good. Suspect splices/bad connection.
Old May 4, 2009 | 02:46 PM
JterrorC's Avatar
Always a Honda =Þ
illl check the splices...its rainin but ohwell..
Old May 4, 2009 | 05:59 PM
JterrorC's Avatar
Always a Honda =Þ
splices are fine....any one else hav any suggestions??
how can i make the corner lights brighter??
Old May 4, 2009 | 08:29 PM
Edward'TLS's Avatar
6G TLX-S
Open up the bad fog light housing and check if the 12V is there when the other fog light is on. Sometime the light bulb contact has corrosion and will prevent 12V from going through. Then check if the ground contact on the bad fog light is still good. Finally, the wire(s) (12V, ground) from the relay to the bad fog light are probably bad, replace them.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
