fog light out..need knowledge
6G TLX-S
Open up the bad fog light housing and check if the 12V is there when the other fog light is on. Sometime the light bulb contact has corrosion and will prevent 12V from going through. Then check if the ground contact on the bad fog light is still good. Finally, the wire(s) (12V, ground) from the relay to the bad fog light are probably bad, replace them.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
