Floor wet........
Old Apr 28, 2006 | 11:08 AM
Hitlayers's Avatar
Floor wet........
Yesterday I vacummed my car for the first time since I purchesed it, I noticed the rear driver side rug was completely soaked (where you would put the rear mat) just in the square area, what could cause this? What can I do? It's only in that one area, please help, don't want that wet carpet mold smell to start in my car!!!!!!
Thanks.
Old Apr 28, 2006 | 11:42 AM
fsttyms1's Avatar
Find the leak
Old Apr 28, 2006 | 03:34 PM
Hitlayers's Avatar
Thats not very helpful, I am asking for advise on where to maybe look first since this seems very weird to me
Old Apr 28, 2006 | 10:42 PM
optomos's Avatar
I=X - optomos
Really hard to figure out without looking at the car. Check the trunk where the spare is and see if there is water there.
Old Apr 29, 2006 | 08:36 AM
Hitlayers's Avatar
Yep there is some water in my spare tire well, whats next?
Old Apr 29, 2006 | 09:47 AM
optomos's Avatar
I=X - optomos
Dry up all the water first and then put a hose to the trunk and around the rear door. Then look to see where the water is coming in. The tail light/trunk lid is usually where the water leaks through, but you could have a bad seal around your rear door to.
Old Apr 30, 2006 | 09:30 AM
Hitlayers's Avatar
OK. thanks optomos, I'll do that, my whole trunk is soaked right now, I remember seeing some water in spare tire well before I changed my tails so I doubt thats the problem, so I guess its a seal somewhere, I will keep you updated
Old Apr 30, 2006 | 01:12 PM
fsttyms1's Avatar
it may be from any seal. Your best bet is to dry the interior, then just start working the car with a hose (id start low and work my way up until you see water.
Old May 2, 2006 | 10:00 AM
Hitlayers's Avatar
OK guys don't beat me up with the questions I may ask in this thread and take into consideration I'm in the finance field and I hardly work on cars but where exactly should I spray the water and where are the main points to check on the car?? (sorry may be silly)
Old May 2, 2006 | 10:32 AM
fsttyms1's Avatar
wheel wells are a good place to start. Under teh car tail lights. I would remove as much interior as i could to make spotting it as easy as possibel (ie rear seat, trunk carpet)
Old May 2, 2006 | 11:22 AM
Hitlayers's Avatar
Gotcha, thanks fsttyms1, will do.....Is this a common problem with the 99 TL?? If so what area is usually the culprit?
Old May 2, 2006 | 11:54 AM
fsttyms1's Avatar
ive only seen like 1 or 2 members with a water issue (not sure of their years). Its not common.
Old May 4, 2006 | 03:10 AM
Topher707's Avatar
05 Acura TL: a-spec
Here is what happened. The car used to be over in Louisiana... then there was a hurricane. they made the car look nice and then passed it off 2 u! lol! i hope not!
Old May 4, 2006 | 09:38 AM
optomos's Avatar
I=X - optomos
I had a leak around my rear passenger taillight after I stripped the trunk down to sound deaden it. When it would rain I would have water in the trunk. After I put weight on the trunk lid with all the sound deadening material and put everything back together it stopped.
Old Jul 12, 2006 | 10:44 AM
Hitlayers's Avatar
Hey guys, just an update, I solved the leak probelm in my trunk, but for some reason the floor behind the drivers seat still continues to get wet when it rains, I don't see water coming in anywhere else in the back, could this be coming from underneth the car somewhere?
Old Jul 12, 2006 | 12:01 PM
GreeneggsandHam's Avatar
how did you solve the leak problem in the trunk? was it a bad seal?
The only holes underneath the car are holes for the ebrake cable to come inside the car. There is always a protective boot around those cables so it seals the holes really good. It could be coming in from the bottom side of the door from a possible bad seal. Spray water around the door and in that area and see if you get any water on the floor. Obviously do this once the floor is dry.
Old Jul 12, 2006 | 01:49 PM
Hitlayers's Avatar
Well I put on the 02 tails so I just got some clear silacone and put it all around the housing of the lights, but I will do what you said, it makes sense and seems to be the only way to find out. Thanks!
Old Jul 12, 2006 | 02:22 PM
fsttyms1's Avatar
well then i would say you either didnt solve the problem or you have 2 leaks. Once again i would say to remove all teh interior you can and start hosing it down. Maybe get a sprinkler under teh car a or go thru a car wash with a underbody flush and stert looking.
Old Jul 13, 2006 | 11:24 PM
its either going to be the tail-light seals or the sun-roof drain channel being plugged up
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
baelim
May 10, 2018 09:53 AM
JDM96specCTR
Oct 17, 2015 01:06 PM
