Engine Light Blinking+shaking after New Spark Plugs
Old 08-18-2009 | 09:18 PM
kinghost1's Avatar
I just installed new NGK Iridium IX spark plugs about a hour ago as well as changed my oil.
My check engine light was on before i replaced spark plugs. I drove down the block, and noticed that the check engine light started to blink...and that the idle was really shaky.
What could cause this problem?
I have to fix this fast as i can, because I am going back to college.
Old 08-18-2009 | 09:24 PM
hANDYcaptd's Avatar
It's the Halladay season!
Get the codes pulled and tell us what they are.
But I'd say you probably damaged one or more coil packs when you changed the plugs.
Old 08-18-2009 | 10:43 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Yeah it's a coil pack check to see which cylinder is misdiring and change that coil! The cylinders fire 1-4-2-5-3-6 so if you have misfires in cylinders 2-5-3 then change coil pack 2 and problem solved!!
Old 08-18-2009 | 11:58 PM
kinghost1's Avatar
I rechecked spark plugs to see if they were fully tightened...and 3 of them had at least .5-1 more turn to tight. Problem solved!
Laoch
1G RL (1996-2004)
10-02-2015 03:27 PM
sockr1
10-01-2015 01:31 AM
HeloDown
09-08-2015 06:51 PM
whitesoxsfan12
09-07-2015 04:07 PM
NSolace
09-03-2015 08:14 PM
Quick Reply: Engine Light Blinking+shaking after New Spark Plugs
