Electrical Problem on 2001 TL
Old Apr 8, 2008 | 12:47 PM
shill147's Avatar
4th Gear
Thumbs down Electrical Problem on 2001 TL
I own an '01 TL w/nav with about 150,000 miles on it. I have an intermittent electrical problem. Sometimes the lights on the center console [nav, stereo, climate control] will flick off for just a second. Nav. goes out, stereo flicks off, if I'm running heter or defroster, it has a quick power hit too. Sometimes this will cause my headlights to go out. When the headlights go out, I pull over, flick the headlight control on the stalk, and they come back on. My mechanic replaced the ignition switch about a month ago, the problem stopped, then re-occured last week. Any ideas? Can the dealer easily diagose?
Old Apr 8, 2008 | 01:56 PM
01tl4tl's Avatar
I would inspect the headlight/turn signal switch assembly behind the steering wheel.
That will tweak all your lights, and if its causing a short- could affect other electrical on the same power circuit,
I had 2 wear out on a maxima, the replacement lasted 1 day beyond its 1 year warranty.
Look under the hood at the fuses for headlights and make sure they are all tight and ok
Old Apr 8, 2008 | 02:03 PM
fsttyms1's Avatar
^ That or a multiplex
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
Fandango12
Sep 20, 2015 05:25 PM
brandnewcolony
Sep 12, 2015 10:39 AM
