EGR Valve Recall?
Old Aug 9, 2005 | 12:45 PM
hangbok's Avatar
EGR Valve Recall?
Hey guys,
I was browsing through the forums and found that someone mentioned an EGR Valve Recall. I never heard of it, does one exists? If so, what do they do? Thanks.
Old Aug 30, 2005 | 01:31 PM
martyf's Avatar
6th Gear
I had my car at the dealer for an oil change and they installed an EGR Pipe Kit under warranty. I didn't have any symptoms but the invoice noted "check engine light". They noted the symptom as "L40" and ethe defectcode as "537". The part number was ACC 06175-P8E-A01 "Kit EGR PIPE". My '99 TL is out of warranty but they told me this came under a 14-year, 150,000 Acura warranty.
Old Sep 12, 2005 | 02:41 PM
My99acuraTL
I have the same problem with my 99 Tl that has 101000 miles (failed inspection last week in Boston). I called the ACURA Client services and they will not honor the recall. They said that it had an extended warranty up to 80 000 miles which my car no longer falls into. Is there anyway i can get them to fix it for free. the dealer is askin $400.00 and up?
Is it worth it to pursue Acura Client services to get it fixed or should i just pay it from my own pocket??
Old Sep 12, 2005 | 04:26 PM
fsttyms1's Avatar
So do you have a check engine light on? or a code P0401 showing? if so this is what you want.
or you can do a little search on this forum for that code and just clean the IM yourself
Old Sep 14, 2005 | 03:24 PM
My99acuraTL
i had code P1491/EGR Port clogging which is the same as P0401
two days ago I took the car to an independent mechanic and he changed the EGR kit for $300 (while going the timing belt).
bad news....This morning i had the engine light back on -now it something with the EVAP canister code....
This car is pissing me off....time to change it
Old Sep 14, 2005 | 05:01 PM
fsttyms1's Avatar
those 2 arent the same thing. 1 has to do with clogged ports in the Intake Manifold, the other has to do with the egr
P0401= EGR Insufficient Flow Detected
P1491= EGR Valve Lift Insufficient Detected
Old Sep 15, 2005 | 12:23 PM
My99acuraTL
hey Fsttyms1,
do you consider cleaning the clogged IM ports is an easy task?
I have done some work on other cars plus i have changed the spark plugs on this TL but nothing major...
i might take chance and get it done myslef. i have seen some procedures taking out the intake Manifold but not too percise...
do guys know of any good step by step procedure...i just wanted to do it the right way...
thanks
Old Sep 15, 2005 | 12:39 PM
fsttyms1's Avatar
I dont have one for the 99. the 99 is a little different than the 2000 which i did a diy on.(below)
Your IM is different and only have the 9 bolts to remove to get it off (and the hoses and cables) then you just clean every thing you see
99 IM https://acurazine.com/forums/showthr...light=cleaning
very easy. mine cloged also around 70k and i just did them again not that long ago
Post #4
http://www.acurainspired.com/forums/...showtopic=4003
start off by getting 3 or so cans of SPRAY carb cleaner and acouple small scrub brushes.
if your engine is any thing like the 2nd gen
baisicly you take the plastic engine cover off 4 10-mm bolts. then disconect the battery. they disconect the rubber hose that goes from the air box to the throttle body. continue to unplg any thing that goes to the intake (any plugins hoses) then there are 10 10mm bolts on the top plate (the part that sticks up thru the plastic engine cover) oull that straight up being carefull to not damage teh gasket. then there are like 8 bolts (12mm i think, i cant remember off the top of my head) then you are able to pull the upper part of the intake manifold off (double check before you pull straight up that every thing is disconected) then get your self a nice place to work and start cleaning. (stick a bag over the TB before you hose every thing down like in my pic to be safe)
it sounds like alot but its really easy should take about a hr to do
Old Sep 19, 2005 | 10:37 AM
My99acuraTL
Thanks fsttyms1, you are very helpful. I appreciate it. It sounds like a good project for next weekend. I will try to get ti done next weekend and I will let you know how I dis. thanks again,
K
Old Sep 19, 2005 | 10:44 AM
My99acuraTL
by the way, i changed the canister last weekend and the radiator (it was leaking) now the engine light is gone. Hopefully it will not never come back. Now i can get my inpection sticker (it failed emission couple of weeks ago) both jobs cost me $678.00
Old Sep 19, 2005 | 10:51 AM
fsttyms1's Avatar
No problem.
Bummer on the canister and radiator.
Old Sep 25, 2005 | 12:05 PM
My99acuraTL
hey fsttyms1,
yesterday i cleand the Intake Manifold on my 99-TL (second Gen). It was a pretty easy job to do. excpet for the two bottom hoses attached to the TB. I could not get them to unplug for a while. The whole thing took 2 hours to do. After i was done I took the car for a spin and let me tell you, what a difference !!! the car drives really nice. It feels like NEW. I never seen it reving up to 6500rpm until yesteday, before it would auto-shift at 4500rpm. Big difference...i filled up the gas tank yesterday to check how much difference cleaning the IM would make on gas consumption. I will post my findings next week or two when i fill up gas again...
The time spent was worth it...
thanks for the help...
Khalid
Old Sep 25, 2005 | 12:39 PM
fsttyms1's Avatar
Old Sep 25, 2005 | 01:31 PM
sbuswell's Avatar
I need 2 more gears
IM & TB cleaning is pretty easy, eveyone should do this themselves, paying 300-400 for a mechanic to do it is just highway robbery. also it is fun and you know you did it the right way and cleaned in very well. I have a 99 TL and there is only 1 EGR port and mine was pretty clogged, I cleaned it up really good and installed thermblok spacers and it made a nice difference in power and response. the hoses on the botton of the TB are by far the hardest step to taking off entire IM & TB, so that is pretty good sign that a few hoses are the biggest obstacles you will face when doing this.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
