Eastern and Catco converters
Old Feb 1, 2009 | 03:43 PM
MBP_TL's Avatar
6MT NBP UA7
Thinking of changing my cat but wanted a 2nd opinion on the Eastern brand and Catco brand. Anyone ever use either of these 2? Any issues? Please let me know. Thanks.
Old Feb 1, 2009 | 04:33 PM
TLer trash's Avatar
Are you trying to gain performance, or do you have a driveability or check engine light problem? There are different solutions depending on your answer.
Old Feb 1, 2009 | 07:01 PM
MBP_TL's Avatar
6MT NBP UA7
CEL problem. 2 o2 changed. EGR ports cleaned out and manifold removed and cleaned with port hole sleeve installed. Still a P0420 showing on the scanner.
Old Feb 1, 2009 | 10:09 PM
Rajca's Avatar
wham bam thank you ma'am
i might have a oem cat with 60k on it from a type s engine for sale by the end of the week.
Old Feb 2, 2009 | 08:21 AM
MBP_TL's Avatar
6MT NBP UA7
Will a Type-S cat be compatible with a 99?
Old Feb 2, 2009 | 11:27 PM
Rajca's Avatar
it might but i think the 02 sensor wires need to be extended. someone that know more can chim in on this
Old Feb 4, 2009 | 11:29 AM
TLer trash's Avatar
I'm fairly sure you would have to modify the mounting holes in the rear flange to make it work. To put a tlp convertor on a tls, you have to elongate the mounting holes outward. I'm guessing it would work the other way. If you're looking for a cheap way to keep the light off, check into a spark plug non fouler to space the rear o2 out a bit. I think excelerate has ones that fit without modification.
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
hpfiend
Sep 27, 2015 06:59 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
ivegotthenav
Sep 11, 2015 07:51 PM
alan_rich
Sep 7, 2015 11:08 PM
