DVD Navigation error message
Old Apr 10, 2007 | 12:27 AM
baddbenny's Avatar
Ok - so I searched the threads... no one yell at the newbie, he followed protocall....
Didnt come up with what I needed to see. Seems most of the info is about errors with the Hard Disk of the '99s... I have a 2000 with the DVD and am currently running the 2.05b version disc. Every so often -normally during the initial start up - sometimes in mid process - My screen comes up with an error message about an "unformatted disc" ... Blue screen with a yellow box containing the message - no navigation action...
Sometimes it will just go away and fix itself, other times I have to turn the car off and back on to get it coerrected... Its quirky, not broken... I asked the dealer and they said I needed the updated Nav DVD - 2.06 or something now. Anyhow, I want the update, but honestly dont see how that would be the fix to the problem. Doesnt make sence to me. Can anyone enlighten me to a possible solution?
Thanks~~!
Benny C
Old Apr 10, 2007 | 01:04 AM
Lawaia's Avatar
Moderator Alumnus
Clean the DVD reader, along with cleaning the DVD map disk.
Old Apr 10, 2007 | 09:37 AM
Bob_F's Avatar
How do you clean the DVD reader? Can you use one of those DVD/CD lens cleaning discs?
Bob
Old Apr 10, 2007 | 02:44 PM
baddbenny's Avatar
Thanks LAWAIA!
Ill give that a shot and see what comes of it.
BOB_F
Yes - go nab up a DVD cleaning disc and give it a run through on your drive. Im gonna give it a shot today and I will let you know how it goes.
Old Apr 10, 2007 | 03:24 PM
Bob_F's Avatar
Originally Posted by baddbenny
BOB_F
Thanks. I have a DVD/CD lens cleaning disc but it's the type where you need to play a particular track for cleaning. With the navigation system I don't see any way to play a particular track. So I'm not quite sure how that would work.
Good luck with your cleaning attempt! I'll be curious to see how it works out.
Bob
Old Apr 10, 2007 | 05:19 PM
baddbenny's Avatar
Bob
You pose a good point... I too recall that the last cleaner kit I used had a "track" you played to use the cleaner. Sooo... hmmm, I suppose I will have to ask about returning it if it doesnt meet my needs - hahahaaaa (evil laugh from the cheap-ass consumer)
We'll see - fingers crossed~
Old Jul 6, 2007 | 08:07 PM
baddbenny's Avatar
well - I CANT find a disc that will clean my drive.... WHAT NEXT???
sorry to double post... odd...
baddbenny's Avatar
well - I cant find a disc that will clean my drive.... WHAT NEXT???
Old Nov 4, 2007 | 02:57 PM
ImInspired's Avatar
i have this problem too....
Old Jan 28, 2008 | 06:44 AM
pinoypassion1's Avatar
4th Gear
navigation error unformatted
I just installed a navigation system on a 02 tl. I got on ebay. my tl did not came with the navi. anyhow, after a long week of install. I ran to this problem. (unformatted)
Is the drive bad or the disc is not any good? I have the 2.30 disc black.
can anyone help me resolve this problem. Please.............
Old Feb 16, 2008 | 04:22 PM
gshantanu's Avatar
Hey, were you ever able to resolve this problem ? I had/have the same problem too.
I got a DVD drive cleaner from Walmart and forced it into my Acura's DVD drive. The cleaner spinned for a little while and then I took it out.
Now, the drive seems to be working alright, but I have not tested it thoroughly.
Old Feb 16, 2008 | 05:34 PM
Bob_F's Avatar
What the brand and model number on that WalMart DVD drive cleaner?
Do the instructions mention selection of a particular track on the disc?
Old Feb 17, 2008 | 09:03 AM
gshantanu's Avatar
It was a Philips CD/DVD lens cleaner. No real model number mentioned. It was the only Philips cleaner there..The instructions did require selection of a particular track. But of course, I could not do that with Acura DVD drive.
As far as I understand, these cleaners just have brushes that need to go over the lens of the drive a couple of times. I assume that took place when I inserted the cleaner DVD into the drive. Also please be aware that I have not tested it thoroughly, I am going to put my navigation unit on/off multiple times today to make sure the thing actually worked. Will put the update here...
Old Feb 17, 2008 | 11:13 AM
Bob_F's Avatar
Thanks for the information. I think I bought the same Philips laser lens cleaner from WalMart. The disc itself doesn't have a model number on it but the cardboard packaging has "PH62022" in small print on the front and back. The disc itself is white and blue with a Philips label on the left a "Laser lens cleaner" label in the center.
I tried to use that without any success on a TL navigation DVD unit but that unit turned out to be defective. (Lens cleaning wouldn't have helped even it it worked.)
Old Feb 17, 2008 | 01:14 PM
gshantanu's Avatar
My attempts failed as well. I switched on my car about 10 times today and in 30% of the cases the incorrect disc error message appeared. Is there some way to know if the DVD unit is defective ?
Old Feb 17, 2008 | 02:51 PM
Bob_F's Avatar
Other than sending it off to Alpine for repair, I don't know of any sure way to find out.
Im my case, I bought another one and that one works perfectly.
Old Feb 18, 2008 | 10:05 AM
gshantanu's Avatar
Thanks for your reply, I guess I'll do that as well.
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
rockyboy
Sep 25, 2015 10:44 AM
