Driver Seat Creaking
Old Jan 14, 2008 | 07:23 PM
Tampa3.2TL's Avatar
7th Gear
Cool Driver Seat Creaking
I just picked up this 03 3.2TL for a great deal w/ 50k miles on it. I figured it'd be a great car...it seems like the problems might be starting..
About a week after picking it up, the seat started creaking, and it moves as if the bolts are loose to the floor..but I checked them, they're all tight. It's gotta be moving on the track to some exent..i really have no idea.
Any ideas on a fix/solution..the creaking is killing me..I want to fix it b/c I do like the car...
Old Jan 14, 2008 | 07:55 PM
02type-s's Avatar
-Arsenic-
The creaking is coming from where your seatbelt fastens on the right side of the seat. (between seat and center console) Spray a LITTLE WD40 on the bolt where it pivots.
Old Jan 14, 2008 | 08:25 PM
Tampa3.2TL's Avatar
7th Gear
I did exactly that when it first started happening...just did it again..and it got rid of the creaking for the meantime...but the whole seat is pivoting on that axis it seems
Old Jan 14, 2008 | 08:26 PM
Tampa3.2TL's Avatar
7th Gear
Old Jan 15, 2008 | 05:59 PM
02type-s's Avatar
-Arsenic-
Maybe the tracks are bent or loose. You checked all the bolts? Try removing the seat and looking underneath it for anything.
Old Jan 15, 2008 | 06:06 PM
Tampa3.2TL's Avatar
7th Gear
Is there a thread on how to remove the seat
Old Jan 20, 2008 | 12:29 PM
pgarratt's Avatar
Yes, you will have to remove the seat to tighten all of the bolts. Mine does/did this too. I had a dealer tighten them once when the car was under warrenty.
Just be careful not to scratch any trim when removing the seat!
Old Jan 20, 2008 | 01:58 PM
burnerjunky's Avatar
Registered Pimp
this has happened to quite a few tls, so i've noticed. It does it to me too, and its a bitch to have the whole seat rock foreward when i stop a little hard.
Old Feb 12, 2008 | 10:54 PM
patrol's Avatar
7th Gear
its the air bag
Old Mar 10, 2008 | 09:03 PM
mcflyguy24's Avatar
Update. I just rasied the seat all the way up, put a towel down on the floor and sprayed every bolt under the seat with WD-40, then moved the seat around in every position imagineable and voila! problem solved.
Old Mar 12, 2008 | 09:27 PM
abusive's Avatar
WD-40 at the belt fastner and on each side of the seat (behind the plastic side guards) and you should be good to go..
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
cm561
Jan 27, 2016 10:17 PM
kareshi
Sep 3, 2015 03:38 PM
