Doors unlock when the car is on
1 Post
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Any1 else have dis issuse when your car is on do your doors unlock??????? Bcuz I have dis issuse it does it when it wants to then it stops so let me know if you do and y does it do that thanx and what I can do so it could stop
Faulty Door Lock perhaps? try to disconnect your Main Drivers Lock by Removing Door Handle and if it Still happends then Try the Passenger Lock.
One of the two must be Going South..... Also check your Key Fob Battery.
Disconnect it after You lock it then turn on your Car and Wait to see if Auto Unlocks again!
If it dont = Then you Need to Replace the Button.
If it does = Check the Passengers Button.
If your talking about if you try to lock your doors when the car is "on" and running (key in ignition motor using gas), thats there so the car doesn't lock you out. You cant disable it.
1 Post
I disconnected it and connected it and turned on the car but didn't seem 2 do it again....And I'm talkin bout when my car is running and driving I can hear my doors unlock constantly then I lock and unlock my doors myself then it stops for awhile......And another thing sometimes when I turn off my car and I lock it I guess the stock alarm BEEPS once then like I never knew it did that so I tend to lock it again and it won't beep again anymore.
Yes The Stock alarm will do a Beep from the Alarm Beeper in the Front Bumper to remind you that you have already locked your Car this is doable by Locking your car with the Fob then clicking the Lock Buttom again quickly youll hear a Beep everytime you Lock it Again and Again.
If you dont hear a Beep your Alarm is Not Set properly, A door is left open or the Tunk is Open etc.
Keyless Entry Remote!
Sorry lol I Meant: Keyless FOB.
Just Lock it 1 Time then Quickly Lock it Again you should hear a BEEP its a Reminder to let you know that your Alarm is Set!
Im having a similar issue. My locks won't even unlock when I place my TL Type-S 02' in park. And my rear passenger door is not locking with the button. I don't know wat to do.
1 Post
Oh but all my doors do lock and they are closed all the way and my trunk too but everytime I click it the 2nd time it won't beep is it possible that there mite be sumthing wrong wit the beeper? Oh and where exactly is it located at so I can take alook at it?
If it doesnt beep then your Alarm isnt Setting check Your Hood Latch Sensor or In a Very Wierd case your buzzer is Shot.
![](http://i882.photobucket.com/albums/ac29/Skirmich/BUZZERPIC.jpg)
Remember to Lock it Quickly in the Keyless Remote it Should BEEP if it Doesnt your OEM ALARM isnt Setting.
tman570
06-11-2019 07:56 AM
handsom-hustla
11-13-2015 05:04 PM
