Door only unlock dont lock from button
Im about to address the issue of my door locks. So here is the issue. If I sit inside the car and press unlock, it will unlock ONLY the back doors. This is the issue on BOTH front doors. If i try to click lock, nothing happens. No doors lock. It is fine if I use the key, but here is the second problem. If i lock it from outside with the key from the PASSENGER door it will lock all doors except the drivers door. If I try it from the DRIVER door with the key from the outside only driver door locks. All the other doors do nothing. Any ideas before I start taking things apart? Im thinking the actuator but I may be totally wrong.
mlody
12-04-2019 02:11 PM
