Dome Lights wont turn off!
I went to replace a map light and ended up blowing a fuse (what i thought). Turns out i did and i replaced the fuse with the correct 7.5A. Now when i lock the car, the dome light wont turn off and when i open the door, the light flickers and the power is not constant, only when in the door position.
When i turn the dial to on, the dome current is strong and doesnt flicker. When i turn it back to auto, the light flickers and stays on when the car is locked. Why is the light not dimming? Any help?
Ill try that, just curious, which ones are the door pins.
I just tried to replace a map light while the door was open. Then before you know it the lights go out.
UNPlug the door pin switches. See if the lights go off. If not its probably the multiplex. There is NO reason not to try to get one used, just buy it from a salvage yard that has something like a 30 day warranty that way if it doesnt work you can give it back.
be carefull when getting a used mulitplex if it is bad youll f up your computer thats what happend to me. I was lucky that some how it was still under warrenty. or that would be $1300. To be safe I suggest you go to the dealer or a shop that deals with car electronics to get it looked at.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
. any ideas on how to approach this kind of issue?
Is there any alternative to get my fuse model working normally again?
