Dome light not coming on with drivers side front door 02' TL-S
5th Gear
Hello All - I'm new here, and just purchased an 02' TL-S with 99k miles.
Love it so far, just a few small problems. When the drivers side front door is open, the dome light will not come on, and the door ajar indicator does not light up.
I confirmed all other doors work with no issue, and assume it's a bad sensor in the door. Problem is, I can't seem to locate the part. Any suggestions?
Welcome DEP_Type-S !!!
Sorta appears to be a bad switch for the driver's door.....if all the others work ok.
It's located in the middle of the center post, right below the latch's striker.....black rubber thingy.
DEP_Type-S (09-27-2014)
5th Gear
Thanks for the quick response! I'm going to mess with it, and order from OEMacuraparts.com if that seems to be the problem. If anyone has any advice on replacing, or knows the part number that would be appreciated as well.
Yeah, it's a basically a simple switch. The driver's door gets a bit more of a workout.
Try wiggling it around. Ya could try swapping the passenger side's door switch with the driver's.
There's only a phillip's screw holding it on.
handsom-hustla
11-13-2015 05:04 PM
nanos
11-12-2015 08:41 PM
09-04-2015 08:03 AM
