Dirty EGR
Dirty EGR
I went to autozone about a week ago because of my check engine light and found out it was due to my EGR valve being dirty, he said from cheap gasoline, and recommended I get a bottle of Chevron Techron complete fuel system cleaner, since I just got the car about 2 weeks ago not sure if the previous owner was using cheap gas or not I've been use Hess premium, my check engine light went off for a week and I thought the chevron had acutually worked and cleaned my EGR valve, but today it came back on.
Any suggestions on what I should do next? Possibly clean the EGR valve myself...
Not sure
Not sure
here ya go. i did this awhile ago
Here is the breif diy i did on it
this one still has a few pics left
Post #4
http://www.acurainspired.com/forums/...showtopic=4003
start off by getting 3 or so cans of SPRAY carb cleaner and acouple small scrub brushes.
if your engine is any thing like the 2nd gen
baisicly you take the plastic engine cover off 4 10-mm bolts. then disconect the battery. they disconect the rubber hose that goes from the air box to the throttle body. continue to unplg any thing that goes to the intake (any plugins hoses) then there are 10 10mm bolts on the top plate (the part that sticks up thru the plastic engine cover) oull that straight up being carefull to not damage teh gasket. then there are like 8 bolts (12mm i think, i cant remember off the top of my head) then you are able to pull the upper part of the intake manifold off (double check before you pull straight up that every thing is disconected) then get your self a nice place to work and start cleaning. (stick a bag over the TB before you hose every thing down like in my pic to be safe)
it sounds like alot but its really easy should take about a hr to do
Post #4
Great DIY instructions, but I work in the financial field and plus just got this car so I would probably be a little hesitant to do this, is there any other treatments I could put in my car to clear up this problem, or is it really not as difficult as it seems????
There is nothing you can put in as far as a treatment. Its not as hard as it seems. You dont have to be in the auto field to do it. Im not. If you have simple metric hand tools a novice could do it in 2hrs or less. Many have. its fairly straight forward once you look at things.
Originally Posted by xanctus
mamamia, I didn't know that Acura TL has an EGR problem just like many Diesel cars on VWs...
well good to hear that...I begin to dislike my TDi nowdays... ![Rolling](https://acurazine.com/forums/images/smilies/rolling.gif)
well I like the fact that diesel can save lots of $$$ on the gasoline bills, but I just can't stand the electrical things that has been happening in my vw. ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
well hopefully I can go back to honda/acura life again.
guys..please..just stop..
don't take your Acura to autozone for a check engine light.
dont spray any fuel system cleaner in your car. especially with the words "chevron".
The code is probably a P0401- EGR VALVE LIFT INSUFFICIENT.
you need to replace the Egr valve and depending on what year you have..the intake plenum needs to be cleaned with a steel sleeve installed to re-inforce the egr port.
your fuel cleaner never worked...when the code was cleared it stayed off until the ECU ran through each readiness code. EGR codes, once cleared or reset..will stay off for about a week.
Originally Posted by fsttyms1
Well these instructions work.( because its exactly what a acura mechanic did) and no one said to spray it in the car. the instructions are for removing and cleaning the IM for the clogged ports. Hasnt been a single issue from a single person in here from doing it and there have been atleast 100 that have done it in the last year
Ok and what i said involves you in what way?
Your instructions seemed to be on point. But for 99' TL's a steel sleeve is installed to the EGR port to prevent future clogging. May also be for the 00' TL's im not sure the exact years. i know the 99 TL's get them. Also The EGR valve itself should be replaced. If the port inside the plenum is clogged, so is the EGR valve.
The fuel system cleaner i said not to use was the chevron techron crap he had put in it.. Acura has it's own method of fuel injection cleaning.
Not trying to fight. I thought you were directing your coment on not spraying any thing in the engine cause i said to get acouple spray cans of cleaner.
Originally Posted by sbuswell
so what is Acura's method for cleaning injectors and EGR port/valve?
The EGR port cleaning is "fairly" well explained in fstty's article. Few things are left out.
The fuel injection service is extensive and i am definitely not typing the whole procedure on here. One of the 3 steps is throttle cleaning which fstty also describes. Maybe if i feel like it sometime i'll type up the article. It's a very good service and highly effective cleaning method.
Skeet Skeet Skeet
I need 2 more gears
most honda engine are very easy to work on yourself. I do most everything myself but delicate things like a crank pulley for instance. Major parts of your engine that are estential to your car should really be handled by someone very knowledgable and if you are confident you can do it yourself then you shoudl bring it to someone like that, like a dealer.
Just so you know.. Autozone can only check generic DTC's(diagnostic trouble codes).. if there's a problem in the idle air control system..the code will come up "idle control/map sensor malfunction" or something of that sort as a generic code.. Our honda scanners give precise codes that are stored in your ECU and give us precise places to look for faults in your vehicle.
theres a reason that the autozone scanner costs 200$ and our honda scanner is over $5000..
think about that..
good luck.
think about that..
good luck.
05 C230K & 09 135i 6MT
Autozone is still a great place to start... if it's a common code you won't pay a dime to diagnose it. I'll take my cars there first, if the code they reveal is unhelpful, then I'll take it to a dealer to have it read with the Honda version.
but every generic code could be unhelpful because it only reads which system in the car has a malfunction..not the part or which part is getting low or high voltage or if theres even a short to ground in the wiring.
Although, Autozone is free..;P
can't beat free, but waste of time sometimes? yeah..
Received 1,080 Likes
think about that..
good luck.
think about that..
good luck.
My $100 Actron scanner has properly diagnosed every DTC for me. Considering what Acura charges for simple diagnoses, I'll stick with mine.
YRMV
I need 2 more gears
I have cleaned my TB, TB cables, IM and EGR port myself when I put on my thermoblok spacers. It is very easy. I want to know how to clean my fuel injectors other than running some fuel system cleaner. Please point me to the article you are mentioning.
