Dashboard Lights + Help!
Old Apr 11, 2011 | 03:12 PM
tjkazai's Avatar
2002 Acura TL
Question Dashboard Lights + Help!
Hello,
My dashboard lights keep popping up.
How can I fix this?
these are the light's that pop up.
- ABS
- SRS
- DRL
- Brake Lamp
- TCS
- check Engine
- Maintenance Req'd
Can you explain some of them for me?
I fixed this one time by doing some trick..
But yeah..
That's all Maybe it some type of glitch?
._.
Anyway's
I need someone to REPLY ASAP!
I need this fixed!
- Kazai
Old Apr 11, 2011 | 03:57 PM
tjkazai's Avatar
2002 Acura TL
Bump
22020202020 please?
- kazai
Old Apr 11, 2011 | 04:00 PM
ecaf005's Avatar
i had some weird dash lights come up when one of my battery terminals was loose..not sure if this is your issue but easy thing to check.
Old Apr 11, 2011 | 04:07 PM
jd88's Avatar
Originally Posted by tjkazai
Bump
22020202020 please?
- kazai
Check battery terminals for wear or carbon deposit. Clean them if needed. If it still shows up after that it could be your alternator. get it checked.
Old Apr 11, 2011 | 07:44 PM
fsttyms1's Avatar
do they all come on at once or just randomly by them selves?
Old Apr 23, 2011 | 05:43 PM
tjkazai's Avatar
2002 Acura TL
It just pops up whenever the car is on ( III )
Oh god -.-
Old Apr 23, 2011 | 06:23 PM
Edward'TLS's Avatar
6G TLX-S
Try reset the PCM.
Disconnect the negative ground cable from the battery. Wait a couple minutes, then reconnect.
Old Apr 23, 2011 | 06:33 PM
Edward'TLS's Avatar
6G TLX-S
One more thing.
Check your battery. If your battery is going bad, the voltage will drop a lot under load (when key is at III), and the PCM will go crazy due to insufficient voltage.
Old Apr 23, 2011 | 06:41 PM
01tl4tl's Avatar
we can reset the ECU by pulling the CLOCK fuse..(its secret backup power)
on passenger end of dashboard
so you dont have to input the radio security code or lose any stations etc
Old Apr 27, 2011 | 08:49 PM
eyesnake02's Avatar
on my sister honda accord when all the lights turn on and stays on. the problem is the alternator
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Sep 14, 2015 10:09 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
