condensation in headlight
Old 03-12-2012 | 09:42 AM
Dariusp91's Avatar
How do I remove it without opening the housing again?
Old 03-12-2012 | 11:06 AM
01tl4tl's Avatar
it will self-dry as the moisture drips out a drain hole/wire pathway on the bottem
You may be able to fix with silicone seal on the outside of seal edge
and dont use a pressure wash on the headlight area
BUT
that moisture drips out, then hits the ballast and fries it!
Once you have moisture, you may as well plan on replacement of ballast-ignitor and bulbs--do both sides
a good kit from hidextra is only $59!! U$D unreal low price and in use by many on here without problems
Old 03-14-2012 | 09:33 AM
acutee's Avatar
Fix the moisture problem as soon as you can or you will face other major problems with ballast and other related items.
Old 03-14-2012 | 11:07 AM
01tl4tl's Avatar
good ol Silicone seal applied along the lens seal to housing should take care of you
beyond that, dont use drive thru/quarter car washes- high pressure water will make its way inside the lens again
Old 03-15-2012 | 10:55 PM
cbburfield's Avatar
3rd Gear
Condensation killed my xenon lights and they're a pain to replace because mine need a security torx head. It'll kill the light so take it off, dry it out and silicon sealer. I had some lying around from other repairs but any good waterproof sealant for cars will work. Use it on the back and you'll be good to go.
hashbrown
02-18-2022 11:20 AM
Mr.Tea
10-02-2015 10:32 PM
MilanoRedDashR
09-27-2015 10:15 PM
h22lude
09-27-2015 06:22 PM
AmplifiedDetails
09-24-2015 02:55 PM
Quick Reply: condensation in headlight
