Code Po132 Please Help
Old Dec 2, 2007 | 07:34 PM
2ndgentl's Avatar
Ok I wrote a little while ago about a slight hesitation at low RPM's. Now it almost falls on its face. It only does it sometimes, but more often now. So i bought one of those OBD 2 scanners and the code its throwing off is PO132 O2 SENSOR CIRCUIT HIGH VOLTAGE (BANK 1 SENSOR 1). What the hell does that mean? Please someone tell me what it is and if its bad, thanks.
Old Dec 2, 2007 | 09:00 PM
fsttyms1's Avatar
you have your cat gutted. It most likely caused your O2 sensor to get fried.
Old Dec 2, 2007 | 09:37 PM
2ndgentl's Avatar
2ndgentl
Yeah but which sensor? Not the one thats on the cat, that has nothing to do with that code. That throws a different code po401.
Old Dec 3, 2007 | 09:48 AM
fsttyms1's Avatar
Its the front sensor O2. Those things are VERY sensitive and damage easily. If your car was running rich or lean due to not having a cat (which it probably was) it probably fried the sensor which is causing the ECU to go nuts because of the wrong signals its getting
Old Dec 3, 2007 | 10:14 AM
2ndgentl's Avatar
2ndgentl
You are definitely right. I jacked my car up lastnight and inspected the front o2 sensor and when I installed the XS headers with the downpipe it looked like the wires were very twisted up when I screwed that sensor on. So I rescrewed it on there making sure the wires werent twisted and guess what.....................My car runs perfectly fine with no more hesitations. Damn, I guess they are extremely sensitive. I appreciate it very much man, thanks a whole lot now I can go back to beating the hell out of my car.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
