Cleaning carbon from engine
Old Sep 16, 2008 | 10:38 AM
swatter's Avatar
My 2000 3.2TL suffers from piston slap in the #5 cylinder. I have read this may be caused by carbon build up. I have also read there is a product called Seafoam which can be used to clean carbon from a car’s upper engine. It is fed into the intake manifold through a vacuum line. Has anyone ever used this product on a 3.2TL? Are there any major concerns with using such a product? Any other thoughts on the piston slap? My car has 160KM
Old Sep 16, 2008 | 11:26 AM
TequiLa's Avatar
(ಠДಠ)
use the search button plz
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/diy-seafoam-2nd-gen-tl-sorta-work-progress-631398/
Old Sep 16, 2008 | 01:18 PM
goldendragon576's Avatar
TL-S driver
just look up Seafoam, you'll find LOTS of threads about it and how great it is. Deep Creep is Seafoam in a spray can which makes it easier to control. If you haven't used it...get on it! There is a DIY for all generations.
Old Sep 16, 2008 | 04:58 PM
01tl4tl's Avatar
I doubt your TL has piston slap- these engines run tight- 200k miles is barely broken in.
It may help to do a cleaning of the oil system as well-
install a new oil filter, add 1 can of seafoam to the engine oil and drive. See seafoam diy and website for details on monitoring and when to change--
100 miles drive and change oil and filter- along with the gas tank and vac port at the throttle body- plus spray clean the Throttle Body plate inside its housing- that gets really bad from smog equipment
Report back with results
oyayjoe
Jan 1, 2019 10:17 PM
Sep 15, 2015 06:44 PM
Sep 14, 2015 10:09 PM
Sep 14, 2015 10:10 AM
oyayjoe
Sep 12, 2015 04:40 PM
