Changing Spark Plugs
Originally Posted by TX-Miner
Possibly a loose connector at one of the coil packs. Perhaps the coil pack not installed properly (loose screw, poor connection on plug).
Is the misfire code specific to 1 cylinder? If so, remove that coil pack and move to another cyl. If the problem misfire moves to the new cyl, the coil pack is likely bad (perhaps a bent pin).
Miner
Miner
Originally Posted by bibledriver
Also, what kind of plugs did you use. Did you gap them yourself (if not iridium plugs) or did you ensure they were pregapped? Sounds like the engine is running fine; is this correct (just CEL and codes)?
NGK right- not Egk?
99?- did that have the plug wires still, or does it have a seperate coil on top of each spark plug?
If seperate coils- check all the electrical connectors are in tight.
It was doing exactly` what` that caused you to get the codes read before, and buy plugs?
How many miles on the car now?
SO new plugs didnt cure a misfire- you need to figure out the real problem.
We need more specifics
Originally Posted by 01tl4tl
NGK right- not Egk?
c1, c3,c2,c4,c5,c6, random misfire.
so i changed out the plugs and i was perfect(i reset the computer as well by disconnecting the neg on the battery also running around trying to remember my radio code
) for a little over a week, and when i was on my way to work the CEL popped up again and i pulled over and plugged in the OBD: all except for c6, random misfire. today is my day off so i want to nip this problem. thank you guys for all of your help\ideas, i knew i loved this forum
If the 99 does have a coil and distributor, also look at the distributor cap and rotor. The rotor "touches" all 6 plugs every set of firing. 100,000 mi on a cap is pretty good. If the CELs come back, I'd look there as well as the coil. Plug wires do wear down as well, but they tend to misfire on a single cylinder at first.
Miner
Miner
99s had some sort of extended warranty on the tune up parts like cap and rotor iirc
emissions test related~ call acura 1-800-382-2238x5 and ask if you are covered
and tell us what wires you played with to fix it
Miner
Miner
Originally Posted by Deflocks
I just unplugged all the wires and re-plugged them back in and reset the comp and its gone, must have been a loose wire then. Thanks for ll your help guys
1) That a good look at the coil high voltage terminal, make sure the spring and terminal are in place. Sometimes the terminal falls off the spring.
2) Look at the coil for any signs of carbon traces along the plastic coil body or the high voltage insulator boot. If it's there make sure to clean it off.
3) Sometimes sparkplugs come with two contact tips, one short and one long (all the NGK's I've used recently came with only the tip on the plug which is pernament). I believe all the Acura's and Honda's use the long terminal tip.
Uncle. I give in to end this discussion.;-)
I going to change my timing belt, water pump and sparky plugs right now.
miner
miner
I've always replaced the water pumps. Anti-freeze and brake fluid also very good to replace every 2-3 years, good preventive maintenance. However I've never replaced the power steering fluid on any Honda, IMO there's no reason to do so with the Honda racks and pumps.
Originally Posted by Munda
I've read there is a DIY on changing spark plugs. But everytime I've searched "Spark plugs" in the "DIY Mod section", I don't get any return threads.
Any help? Thanks
Any help? Thanks
Hmmm? I don't find an actual DIY either.
I did turn these up and there are some tips, but you've gotta sort through the threads (ignore the seat memory thread).
https://acurazine.com/forums/search.php?searchid=894902
Didn't find a 3G DIY either.
I dont know if there is a DIY. Its pretty straight forward. Take off the engine cover, use a metric allen wrench to remove the coil and remove the spark plugs. The rears are the same. If you have a type s remove the 2 bolts that hold the IMRC motor on and swing out of the way. Once thats out of the way the rears can be accessed easier. It helps having a 6" and a 3" extension for this job.
Thank you for all those who help others.
I just finished changing spark plugs. It was easier with 3" & 6" extensions, as advised earlier.
I wanted to share my experience with NGK-ZFR5FIX-11. i noticed they were all not gapped properly to the 0.44 as recommended. Also watch out for one of the vacuum lines that is in the way and got pulled, which I didn't notice, until after I drove and found the idle rougher.
Hey small world, my 89 legend replacement water pump failed ~50K miles after replacement. Coolant began leaking from the inspection hole. Don't know for certain but my guess is that I used Prestone Antifreeze with it's large amount of silicates that cause the water pump seals to wear quickly. I never used to believe in OEM premixed anti-freeze until that, so now I used the premixed Honda stuff for all my Honda/Acura cars and motorcycle.
duly noted.
I must agree with tophjoe that the rear three are a major pain. I ended up removing the the two bolts and swinging aside the IMRC toward the passenger side and the bolt for the power steering hose to free up movement as necessary.
changing plugs - oil in chamber
Changing plugs on 04 TL 3.2 - 162,000 miles. Found Oil in the chamber...but plugs were a liitle loose. Any thoughts on how bad this is? Also the little end of the coil ripped off - do you need that ,if so where can I get just that
Resetting the computer can clear the code for a little but it might come back.
