Change Holder
Old Jul 16, 2005 | 05:55 PM
sistom's Avatar
pwnage
Angry Change Holder
Somehow some coins have fallen behind the change holder and now the things won't close shut completely. I can't reach behind it to remove the coins so I am wondering how the hell do I remove the tray so that I can get the damned coins out of it? thx
Old Jul 16, 2005 | 06:23 PM
MikePA's Avatar
Had you done a search on "change holder" you'd have found a message like this...
if wiggling the coin holder up and down does drop the coins then you can remove coin holder by unscrewing shift knob, remove two screws from inside bottom center armrest, pull off both plastic wood trim, remove screws securing armrest and gear shift console and you should be able to retrieve the lost change.
or
i had the same problem and the first time it happened i took it to the dealer and they did it for me, but the second time i was able to use a paper clip and duck tape to get it out, just bend the paper clip to be able to get it back there and wrap the duck tape around the paper clip and slip it back there and try to attach the coin onto the duck tape and gently get it out, it's like playing operation you have to be careful not to touch the sides or the coin could fall down again!!
good luck
I read about this problem here on AZ which is why I don't use the change holder. It's a bad design.
Old Jul 17, 2005 | 01:29 PM
bkzjimmy's Avatar
NiGhT rIdEr
theres about $1000 stuck behind mine.
Old Jul 17, 2005 | 04:13 PM
unlemming's Avatar
Smitty's Moral Police
I don't know which model year this started, but my 02 has a hinged "top" piece with a spring so that the coins aren't able to get back there so easy. I did a similar thing on my 00 and just pushed up the top piece and it worked pretty well. Hard to describe, but here is a bad picture of the coin holder cross section:
___
\_______/
"break" it so it's kind like this:
\_______/
Old Jul 17, 2005 | 04:45 PM
bkzjimmy's Avatar
NiGhT rIdEr
___
\_______/
\_______/
good idea
Old Jul 20, 2005 | 09:23 AM
joseph_99tl's Avatar
never put coins in the coin tray.
Old Jul 25, 2005 | 01:44 PM
***EL*MAFIOSO***'s Avatar
blACk AC in sAC
Smile
___
\_______/
\_______/
i had this happen on my 02 with a quarter a little after i bought it, will breaking that really work and it wont cause any additional problems?
Old Jul 27, 2005 | 02:48 PM
brakejob's Avatar
:brakejob:
where is the change holder?
is this the tray between the seat warmers, where the obd-II plug is? (behind a plastic cover)
Old Jul 27, 2005 | 05:38 PM
MikePA's Avatar
Yes
Old Jul 27, 2005 | 06:07 PM
fsttyms1's Avatar
yes its teh lid that comes down to reveal teh cig lighter. there is a red tray that says NOT an Ashtray. thats the coin holder
Old Jul 27, 2005 | 11:30 PM
bkzjimmy's Avatar
NiGhT rIdEr
how long have u had ur car???
Old Jul 28, 2005 | 08:05 PM
brakejob's Avatar
:brakejob:
lol
it's not really a change holder then, its just a place to put shit... i thought there was some mythical spring loaded coin thing i had yet to see...
ive had my car since 10/2003, and i've have the entire interior gutted before... so i was wondering if i've missed something...
Old Jul 29, 2005 | 12:22 PM
bkzjimmy's Avatar
NiGhT rIdEr
lol
i was just messin witcha lol
Old Jul 30, 2005 | 06:03 PM
blACk AC in sAC
Question
i dont know!
what is change?
Old Jul 31, 2005 | 07:27 PM
bkzjimmy's Avatar
NiGhT rIdEr
Originally Posted by ***EL*MAFIOSO***
i dont know!
what is change?
___
\_______/
\_______/
i just tried this, i hope it works
Old Jul 31, 2005 | 09:15 PM
unlemming's Avatar
If you have an 02 it should already be "spring loaded", which is apparently not perfect but it seems to help. I haven't had any issues with my 02 so far. I didn't have any issues after I modified my 00 as described either, but I'm sure it is still possible to get some change caught up back there if you're lucky
Old Oct 3, 2005 | 07:49 PM
chelo3218's Avatar
change holder
i've had that similar problem in my 99' tl. but its really an easy and annoying fix.
first you have to remove your center console(arm rest).
there should be 2 or srcews in there if my memory serves me right.
once that is removed, you have to remove the cup holders, and the shift tray. once all that is off, you can easily recover all of the lost treasure. mechanical fingers is the best way i found to really get deep in there.
good luck!
Old Jul 30, 2006 | 09:24 AM
takenaflyer's Avatar
This just happened on my '99 TL and after searching the forums I realized an overloaded change holder was jam-up waiting to happen. Anyway, I was able to take 1/4 x 3 x 1/16" piece of soft metal with a 90 degree bend 1/4" from the end, hook the OBD cover and pull it out, and exposing the errant coins. I then folded up a piece of paper to catch the change as I worked it all out with a piece of coat hanger wire. A total of 72 cents later I was back in business.
csmeance
Jan 7, 2026 06:25 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
mugen_kid
Nov 13, 2015 10:38 PM
GraveDigger
Sep 18, 2015 07:46 AM
Aleax
Sep 11, 2015 11:31 AM
