CEL P0141 wont erase !
Old Nov 15, 2010 | 11:55 AM
louuu's Avatar
I got CEL code P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
I went out a bought a new Bosch sensor and replaced it.
Unless I changed the incorrect one, I changed the one that goes plugged into the catalytic converter.
After replacing the plug I tried erasing the code using a OBD-II CEL reader but it just comes right up seconds later.
I've also tried resetting the ECU by removing the clock fuse but didnt have any luck either.
Any advice?
Old Nov 15, 2010 | 04:11 PM
NSXNEXT's Avatar
That is the correct 02 sensor.
Could be that the wiring is bad. Look for melted wire, loose connection at the o2 sensor.
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
samson_420
Oct 8, 2015 01:47 AM
hrothgar02
Sep 28, 2015 11:08 AM
elietania
4G TL Problems & Fixes
Sep 5, 2015 06:52 AM
