CEL blinking, along with exclamation, and traction turned off lights on
P0301 Misfire #1 Cylinder
P1607 PCM Internal Circuit Failure
P0302 Misfire #2 Cylinder
P0303 Misfire #3 Cylinder
P0304 Misfire #4 Cylinder
P0306 Misfire #6 Cylinder
P0300 Random Misfire
P1399 Misfire Inrse Any Cylinder
Hello everyone, noob here begging for any words of wisdom. The suggested course of action is to replace coils and plugs. So I have ordered the NGK Platinum plugs and the NGK coils. Is that going to clear the PCM error code or should I be starting with that?
suggested course of action is to troubleshoot, instead of replacing all plugs..
it could very well be just one cylinder that needs attention. or it could very well mean that your head(s) (specifically the valves) are fucked.
I took justnspace advice and started troubleshooting the coils and plugs, found a bad coil and replaced, but as I also replaced the plug I found the actual source of the misfire was possibly a bad gasket since the plug was covered in oil along with coil.so now I have to dig deeper, anyone have experience with this issue
When oil pools on the outside of the plug it creates an electrical path to ground, essentially shorting out the plug before the energy gets to the electrode, which leads to early coil failure..... Could be that was the cause of your P1607. Keep an eye on it.
